Home » Archived » XML Schema Definition (XSD) » Extension Attributes
Extension Attributes [message #11525] Fri, 28 February 2003 17:43 Go to next message
Originally posted by: dsingh.altoweb.com
Hi all,
I have a question about parsing XSD schemas that are used to describe
web service data types. I use the XSD parser to construct an instance
document and I'm having a slight problem with the following.
<xsd:complexType name="ArrayOfString">
<xsd:complexContent>
<xsd:restriction base="SOAP-ENC:Array>
<attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="string[]"/>
</xsd:restriction>
</xsd:complexContent>
</xsd:complexType>
Is there a way through the API to retrieve the extenstion attributes?
Dharminder Singh
Re: Extension Attributes [message #11563 is a reply to message #11525] Fri, 28 February 2003 18:57 Go to previous message
--------------12AB854ECB31FB69F109F151
Content-Type: text/plain; charset=us-ascii
Dharminder,
You can drop down into the DOM and look for them:
Element attributeElement = xsdAttributeUse.getElement();
if (attributeElement != null &&
attributeElement.hasAttributeNS(WSDL_URI, "arrayType"))
Dharminder Singh wrote:
> Hi all,
> </xsd:restriction>
> </xsd:complexType>
> Thanks
> Dharminder Singh
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Dharminder,
<p>You can drop down into the DOM and look for them:
<blockquote>&nbsp;Element attributeElement = xsdAttributeUse.getElement();
<br>&nbsp;if (attributeElement != null &amp;&amp; attributeElement.hasAttributeNS(WSDL_URI,
"arrayType"))
<br>{
<br>}
<br>&nbsp;</blockquote>
<blockquote TYPE=CITE>Hi all,
<p>I have a question about parsing XSD schemas that are used to describe
<br>web service data types. I use the XSD parser to construct an instance
<br>document and I'm having a slight problem with the following.
<p>&lt;xsd:complexType name="ArrayOfString">
<br>&nbsp; &lt;xsd:complexContent>
<br>&nbsp;&nbsp; &lt;xsd:restriction base="SOAP-ENC:Array>
<br>&nbsp;&nbsp;&nbsp; &lt;attribute ref="SOAP-ENC:arrayType" wsdl:arrayType="string[]"/>
<br>&nbsp;&nbsp; &lt;/xsd:restriction>
<br>&nbsp; &lt;/xsd:complexContent>
<br>&lt;/xsd:complexType>
<p>Is there a way through the API to retrieve the extenstion attributes?
<p>Thanks
<p>Dharminder Singh</blockquote>
</html>
--------------12AB854ECB31FB69F109F151--
Re: Extension Attributes [message #565343 is a reply to message #11525] Fri, 28 February 2003 18:57 Go to previous message
Dharminder,
> Hi all,
> </xsd:restriction>
> </xsd:complexType>
> Thanks
> Dharminder Singh
<html>
Dharminder,
"arrayType"))
<br>{
<br>}
<p>Thanks
</html>
Previous Topic:Extension Attributes
Next Topic:restricting attributes
Current Time: Tue Jul 15 08:27:38 EDT 2025
Powered by FUDForum. Page generated in 0.37557 seconds
