| Eclipse Standalone SWT Tutorial [message #125806] |
Fri, 23 December 2005 19:38 |
Originally posted by: john.nospam.com
I just started with java and eclipse and I was running througth the SWT
tutorial of 3.1.1 but I got stuck on step 3:
1. Select your Java project and from the context menu select Properties.
2. Select the Java Build Path and then click on the Projects tab and
click on the Add button.
3. Place a check beside org.eclipse.swt and click on the OK button twice
to close the dialog.
Because the projects tab is empty??
And if I want to make a standalone application with Java, similar like
compiling to an .exe in Visual Basic, what do I need in Eclipse
(additional tools?)
Thnx!
FUDForum. Page generated in 0.06642 seconds
