Home » Modeling » OCL » Re: OCL-Expression Error
Re: OCL-Expression Error [message #11499] Wed, 14 March 2007 13:53 Go to next message
Irina,
OCL has its own specific newsgroup, so the question is best asked
there. I've added it to the "to" list.
Irina wrote:
> Hi all,
> what's wrong on my OCL-Expression?
> self.allStateFigures->select(oclIsTypeOf(PseudoState)).kind
> Error in (variableExpCS): (Unrecognized variable: (kind))
> This OCL-Expression works!
> self.allStateFigures->select(oclIsTypeOf(PseudoState)).name
> Name is an Attribute of PseudoState Class of Type String and Kind is an
> Attribute of PseudoState Class of Type PseudoStateKind.
> i cann't understand it ;-((
> Help me please.
Re: OCL-Expression Error [message #11536 is a reply to message #11499] Wed, 14 March 2007 18:22 Go to previous message
Hi, Irina,
The type of the self.allStateFigures property is, I assume, Set(Vertex).
(correct me if I'm wrong)
Thus, the type of any select expression on this collection will likewise be
Set(Vertex), not Set(PseudoState). The select expression always returns a
collection of the same element type as the source collection. Your second
example
works because Vertex is a kind of NamedElement, thus has a "name" property.
In the case of
Vertex does not have a "kind" property; this is defined by the PseudoState
metaclass. You need to do the following:
self.allStateFigures->iterate(s; ps : Set(PseudoState) = Set{} |
if s.oclIsTypeOf(PseudoState) then
ps->including(s.oclAsType(PseudoState))
else
ps
endif).kind
Unfortunately, OCL 2.0 does not allow the use of oclAsType() to cast a
collection to another collection type. i.e., you can't just do:
oclIsTypeOf(PseudoState)).oclAsType(Set(PseudoState)).kind
HTH,
Christian
Ed Merks wrote:
> Irina,
> Irina wrote:
>> Hi all,
>> Help me please.
Previous Topic:LoopExp abstractness
Next Topic:How to write constraint for not requiring self transition
Current Time: Tue Jul 08 17:44:23 EDT 2025
Powered by FUDForum. Page generated in 0.04200 seconds
