Using XBootclasspath [message #125372] |
Wed, 21 December 2005 16:41  |
I want to install some class loading debug code,
which involves prepending a couple of classes to
the jvm's xbootclasspath property.
I can not find any information on accessing the
xbootclasspath property in eclipse's jvm. Where can
I find information on how to access the boot classpath
under eclipse?
Bill.
Re: Using XBootclasspath [message #126086 is a reply to message #125506] |
Mon, 26 December 2005 14:02  |
Jeff Myers wrote:
> Hey Bill,
> Do you want to access these bootstrap classes within your IDE
> environment, or within a class you're debugging with Eclipse? If it's
> the latter case, bring up the launch configuration for your app -
> (Run->Debug... then select the launch configuration) Switch to the
> Classpath tab and there's a Bootstrap enteries item to which you can add
> jars, projects, etc. Is this what you're looking for?
> Hope this helps,
> - Jeff
Thanks Jeff,
Apologies for the delayed response, I've been struck by the flu.
I'll try this ASAP,
Bill.
FUDForum. Page generated in 0.08880 seconds
