Home » Archived » Test and Performance Tools Platform (TPTP) » Verification hook problem
Verification hook problem [message #125255] Tue, 04 March 2008 07:10 Go to next message
Originally posted by: gopi_tptp.yahoo.com
hi,
i am using tptp to execute testcases.
after runnig the test cases i had inserted hook point in order to validate
the test case.
in most cases the test cases are executed properly, but some times the
hook doesn't get executed.
it gives the following message
Failed to locate the context view/com.ca.harvest.ui.explorerView required
by the verification point testco39:Qorg.eclipse.ui.IViewPart;
i think this is a memory related problem,because this problem comes not
often.
what are the main causes for this problem????
thanks,
gopi
Re: Verification hook problem [message #125268 is a reply to message #125255] Tue, 04 March 2008 08:29 Go to previous messageGo to next message
Hello, gopi,
We also have engineer encounter this problem on his workstation, but
cannot reproduce on other workstation stably. What's the AGR, TPTP and
Eclipse version you are using?
Jimmy Jin
gopi wrote:
> hi,
> validate the test case.
> required by the verification point testco39:Qorg.eclipse.ui.IViewPart;
> often.
> thanks,
> gopi
Re: Verification hook problem [message #125339 is a reply to message #125268] Tue, 04 March 2008 23:50 Go to previous messageGo to next message
Hi Jimmy,
i am using
TPTP: tptp.runtime.allInOne.win32.win32.x86-TPTP-4.4.0.3(4.4.0.3 version)
AGR: org.eclipse.tptp.test.auto-TPTP-4.4.0.3.zip(4.4.0.3 version)
Eclipse Version: 3.3.1
gopi
Re: Verification hook problem [message #125859 is a reply to message #125255] Mon, 10 March 2008 06:39 Go to previous messageGo to next message
Hi Gopi,
This problem is related to the AGR runner not finding the view part
during playback. I would suggest adding a wait before the call to your
verification hook or using a custom widget resolver to locate the view part
during playback
Paul
"gopi" <gopi_tptp@yahoo.com> wrote in message
news:0b172af5cf23d0678b77572b27ccb5f6$1@www.eclipse.org...
> hi,
> the test case.
> often.
> thanks,
> gopi
Re: Verification hook problem [message #125885 is a reply to message #125859] Mon, 10 March 2008 08:41 Go to previous messageGo to next message
hi paul,
the first alternate is present in the macro code itself i.e while
recording the testcase by agr, wait macro is present(i maen recorded)
before verification hook and after the hook.
could you please tell the second alternate i.e using a custom widget
resolver to locate the view part.
thanks,
gopi
Re: Verification hook problem [message #125910 is a reply to message #125885] Mon, 10 March 2008 09:04 Go to previous message
See
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-5-0.html#2.4.
Paul
news:0e971df042a16a40d7243275aa995644$1@www.eclipse.org...
> hi paul,
> thanks,
> gopi
Previous Topic:General Properties
Next Topic:support for RCP product in TPTP4.5i4 ???
Current Time: Sun Jul 27 07:11:30 EDT 2025
Powered by FUDForum. Page generated in 0.12035 seconds
