Home » Eclipse Projects » GEF » Finding figure under mouse on drag/drop
Finding figure under mouse on drag/drop [message #125204] |
Wed, 31 March 2004 19:09  |
Originally posted by: mas.nospam.com
How do I identify the figure that is underneath the mouse for the drag
operation for the following code?
public class DNDTest
public static void main(String[] args)
Display display= new Display();
final Shell shell = new Shell(display);
shell.setLayout( new GridLayout() );
Composite composite = new Composite( shell, SWT.NONE);
composite.setLayout( new GridLayout() );
final FigureCanvas figureCanvas = new FigureCanvas( composite );
Figure panel = new Figure();
panel.setLayoutManager( new FlowLayout() );
panel.add( new Label("Label1"));
panel.add( new Label("Label2"));
panel.add( new Label("Label3"));
figureCanvas.setContents( panel );
// Allow data to be copied or moved from the drag source
int operations = DND.DROP_MOVE | DND.DROP_COPY;
DragSource canvasSource = new DragSource( figureCanvas,
operations );
canvasSource.addDragListener(new DragSourceListener()
public void dragStart(DragSourceEvent event)
System.out.println("Drag Started");
IFigure afigure = figureCanvas.getContents().findFigureAt(
event.display.getCursorLocation().x,
event.display.getCursorLocation().y);
System.out.println( afigure );
public void dragSetData(DragSourceEvent event) {}
public void dragFinished(DragSourceEvent event){}
shell.open();
while (!shell.isDisposed())
while (!display.readAndDispatch())
display.sleep();
Help is appreciated. MM
Re: Finding figure under mouse on drag/drop [message #125399 is a reply to message #125389] |
Thu, 01 April 2004 10:56   |
My fault. Yes, probably want to hook into MousePressed.
DragStart does not occur until after either:
1) a delay
2) the mouse has moved some amount
In the case of 2), the mouse may no longer be over the original mouse-down
location, and you would get the wrong figure.
"Mas Masoud" <mas@nospam.com> wrote in message
news:c4hdjf$9c1$1@eclipse.org...
> Thanks Randy. After I change it to getViewport(), the figure beneath is
> still returning null. I am assuming the reason being the location.
> Are these calls the right calls to make to get the mouse location or do
> they need to be translated relative to something to get the figure?
> event.display.getCursorLocation().x;
> I am assuming these return the display location but if figures are based
> wrt to the panel they are in, then that could be the problem as the
> findFigureAt call looks at non-existent place. Could this be the mistake
> and if so, can anyone suggest the correct procedure?
> ~MMS
> Randy Hudson wrote:
> > It looks like you already have the code. Except instead of calling
> > getContents(), which reaches in past the viewport figure, you need to
call
> > getViewport(). Otherwise you will be incorrect when the figures are
> > scrolled.
> > news:c4fmjn$ivm$1@eclipse.org...
> > > operations );
> > > shell.open();
> > > display.sleep();
Re: Finding figure under mouse on drag/drop [message #125425 is a reply to message #125412] |
Thu, 01 April 2004 13:08   |
Mouse released does not get called if a native drag starts.
What are you trying to do? You can get the figure under the mouse on
mousedown, and use it whe nthe drag starts.
For DropTargetEvent, the mouse location is provided in the event, so its a
non issue.
news:c4hhaf$em9$1@eclipse.org...
> Thanks. That helped me move ahead.
> I was able to hook a mouseListener and capture the mouse location in the
> mousePressed method. This helped the drag operations.
> But, when I tried the same for drop, meaning, try to find the mouse
> location in the mouseReleased method, it does not seem to get called. Is
> this different?
> I tried getting the location in DropTargetEvent using the
> event.display.getCursorLocation() callback. Does the explaination
> "In the case of 2), the mouse may no longer be over the original
mouse-down
> location, and you would get the wrong figure"
> apply to this drop case as well ? Any suggestions here ?
> Thanks much,
> MMS
Re: Finding figure under mouse on drag/drop [message #125437 is a reply to message #125425] |
Thu, 01 April 2004 16:15   |
I have a panel of figures that can be arranged by drag/drop means into
slots. Now that I can get hold of figure while the drag is occuring via
the mouseListener mechanism, I have no problems.
With respect to drop, if I drop text onto one of these figures, their
contents should get updated. I am not able to identify the figure on which
the drop happened. Once I can identify that, then it is just a matter of
replacing that figure with a new one at the same location.
My problem is when I get the point via mousePressed event, then I get
something like (24,41) but if I check the same point via DropTargetEvent's
event.x, event.y, the values are something like (246,291) which are not
with in my panel. So, findFigureAt returns null.
Is there a different call that I need to make to get the coordinates where
the drop occured?
> non issue.
> > this different?
> mouse-down
> > Thanks much,
> > MMS
Re: Finding figure under mouse on drag/drop [message #125574 is a reply to message #125437] |
Fri, 02 April 2004 10:54   |
Drop events contain display-relative coordinates. See
control.fromDisplay(point).
You may not be using GEF, but you can find your answers to these problem in
the GEF code.
Specifically, AbstractTransferDropTargetAdapter.
"Mas Masoud " <mas@nospam.com> wrote in message
news:c4i0q1$31e$1@eclipse.org...
> the drop occured?
a
> > non issue.
the
Is
> > > this different?
> > mouse-down
> > > Thanks much,
> > > MMS
Re: Finding figure under mouse on drag/drop [message #125611 is a reply to message #125574] |
Fri, 02 April 2004 11:44  |
Thanks Randy. Suggestions helped quite a bit.
Off to the next steps..
> the GEF code.
> > the drop occured?
> a
> > > non issue.
> the
> Is
> > > > this different?
> > > mouse-down
> > > > Thanks much,
> > > > MMS
Current Time: Tue Jul 22 15:29:54 EDT 2025
Powered by FUDForum. Page generated in 0.04813 seconds
