Home » Eclipse Projects » Eclipse Platform » Memory usage and OSX - how much do you have?
Memory usage and OSX - how much do you have? [message #125105] Tue, 09 September 2003 09:26
Originally posted by: adam.sosume.org
hi,
i've been having a recurring problem with both Eclipse 2.1 and M3 (
recently upgraded). When i'm working on a small project (circ. 20-30
classes) Eclipse runs as sweet as you like but when it's faced with a
larger project (50+ classes) that has external libraries, it regularly (
every 3-5 saves) crashes.
after checking the .log file it seems that it's a memory issue.
i went into the eclipse.app (show package contents) and edited the 'info.
plist' file changing the allocated memory for the VM from default to:
<string>-Xms60M</string>
<string>-Xmx500M</string>
to give it LOTS of memory. the problem still occurs.
my set up is a 12"PB 867mhz G4 with 640MB RAM which i would have thought
would be plenty.
now for the questions:
am i alone or do i share the same problem as anyone else?
how much RAM is needed?
is there some easy fix that i've not covered?
i've attached the log as i thought it may be useful.
thanks for your help
adam
  • Attachment: eclipse.log
    (Size: 51.12KB, Downloaded 148 times)
Previous Topic:Cannot save file
Next Topic:Memory usage and OSX - how much do you have?
Current Time: Fri Nov 07 22:13:54 EST 2025
Powered by FUDForum. Page generated in 0.02932 seconds
