Home » Modeling » GMF (Graphical Modeling Framework) » Note-like labels for connections
Note-like labels for connections [message #124964] Wed, 09 May 2007 09:20 Go to next message
Originally posted by: nospam74.gmx.net
Hallo all!
In my metamodel each entity has several attributes. For those
represented as connection I would like to display the attribute value
in a labeled box connected with the connection by a line (just like "Add
Note" from the context menu). But I have no clue, how can I create
several graphical objects at one time.
How can I do that?
Should I add elements, that I need for graphical representation, in my
ECore model?
Greets
Andrej
Re: Note-like labels for connections [message #125081 is a reply to message #124964] Thu, 10 May 2007 04:38 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
Could you please clarify your setup? Link could be based on EClass or
EReference - not attribute; for EReference based link you can't add
attribute-based labels since EReference has no EAttributes.
Andrej S wrote:
> Hallo all!
> How can I do that?
> ECore model?
> Greets
> Andrej
Re: Note-like labels for connections [message #125235 is a reply to message #125081] Thu, 10 May 2007 05:11 Go to previous messageGo to next message
Hi, Dmitry!
My attribute is a EClass.
ecore snip:
<eClassifiers xsi:type="ecore:EClass" name="AttrValue">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="Value"
lowerBound="1" eType="ecore:EDataType
http://www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="parent"
lowerBound="1" eType="#//model/Edge"
eOpposite="#//model/Edge/containsAttrValues"/>
</eClassifiers>
I want to attach AttrValue to an Edge (defined as a EClass), so that it
looks like
edge1
! attr1 !
Andrej
> Andrej S wrote:
>> Hallo all!
>> How can I do that?
>> ECore model?
>> Greets
>> Andrej
Re: Note-like labels for connections [message #125361 is a reply to message #125235] Thu, 10 May 2007 07:58 Go to previous messageGo to next message
Have you managed to get this:
edge1
! attr1 !
Andrej S wrote:
> Hi, Dmitry!
> ecore snip:
> </eClassifiers>
> looks like
> edge1
> ! attr1 !
> Regards
> Andrej
>> Andrej S wrote:
>>> Hallo all!
>>> How can I do that?
>>> ECore model?
>>> Greets
>>> Andrej
Re: Note-like labels for connections [message #125434 is a reply to message #125361] Thu, 10 May 2007 08:29 Go to previous messageGo to next message
No. I have no idea how I can map a attribute figure (composed of
rectangle and a label) to an edge.
> edge1
> ! attr1 !
> Andrej S wrote:
>> Hi, Dmitry!
>> ecore snip:
>> </eClassifiers>
>> looks like
>> edge1
>> ! attr1 !
>> Regards
>> Andrej
>>> Andrej S wrote:
>>>> Hallo all!
>>>> "Add
>>>> How can I do that?
>>>> ECore model?
>>>> Greets
>>>> Andrej
Re: Note-like labels for connections [message #125458 is a reply to message #125434] Thu, 10 May 2007 08:47 Go to previous messageGo to next message
Have a look at TaiPan sample, Route class. Route is mapped to reliable
and unreliable links each with two labels.
>> edge1
>> ! attr1 !
>> Andrej S wrote:
>>> Hi, Dmitry!
>>> ecore snip:
>>> </eClassifiers>
>>> looks like
>>> edge1
>>> ! attr1 !
>>> Regards
>>> Andrej
>>>> Andrej S wrote:
>>>>> Hallo all!
>>>>> "Add
>>>>> How can I do that?
>>>>> ECore model?
>>>>> Greets
>>>>> Andrej
Re: Note-like labels for connections [message #126726 is a reply to message #125458] Wed, 16 May 2007 08:13 Go to previous messageGo to next message
Hallo, Dmitry!
If I try to get a look on taipen.gmfmap I get a lot of errors, such
Feature 'viewMethod' not found.
(platform:/resource/org.eclipse.gmf.examples.taipan/models/t aipan.gmfmap,
17, 31)
Feature 'editMethod' not found.
17, 31)
I am using eclipse 3.3M6 and GMF 2.0M6
Andrej
>>> edge1
>>> ! attr1 !
>>> Andrej S wrote:
>>>> Hi, Dmitry!
>>>> ecore snip:
>>>> </eClassifiers>
>>>> looks like
>>>> edge1
>>>> ! attr1 !
>>>> Regards
>>>> Andrej
Re: Note-like labels for connections [message #126738 is a reply to message #126726] Wed, 16 May 2007 08:20 Go to previous messageGo to next message
So you should work with TaiPan sources when GMF M6 was built - not the HEAD.
Andrej S wrote:
> Hallo, Dmitry!
> 17, 31)
> 17, 31)
> Regards
> Andrej
>>>> edge1
>>>> ! attr1 !
>>>> Andrej S wrote:
>>>>> Hi, Dmitry!
>>>>> ecore snip:
>>>>> </eClassifiers>
>>>>> looks like
>>>>> edge1
>>>>> ! attr1 !
>>>>> Regards
>>>>> Andrej
Re: Note-like labels for connections [message #132957 is a reply to message #126738] Wed, 06 June 2007 04:15 Go to previous messageGo to next message
Thanks for the hint!
But I have some problems:
1. It (I mean to put labels to an edge) works very well in example, but
I can not reply it in my application. Is there things to change
excepting mapping?
2. Labels in the example are statical mapped to the edge, but in my
model arbitrary number of elements (attribute figures) can belong to an
edge.
regards
Andrej
> HEAD.
> Andrej S wrote:
>> Hallo, Dmitry!
>> 17, 31)
>> 17, 31)
>> Regards
>> Andrej
>>>>> edge1
>>>>> ! attr1 !
>>>>> Andrej S wrote:
>>>>>> Hi, Dmitry!
>>>>>> ecore snip:
>>>>>> </eClassifiers>
>>>>>> that it
>>>>>> looks like
>>>>>> edge1
>>>>>> ! attr1 !
>>>>>> Regards
>>>>>> Andrej
Re: Note-like labels for connections [message #133019 is a reply to message #132957] Wed, 06 June 2007 05:20 Go to previous messageGo to next message
1. There should be nothing special; just add the label mapping to the
link mapping.
2. In GMF models you can describe only a fixed number of labels that
will always be available. There are no means to create them or delete -
that's the reason to define them this way. For nodes you may define
child nodes with single label that will be presented as labels; see
'small items' in TaiPan sample.
> excepting mapping?
> edge.
> regards
> Andrej
>> HEAD.
>> Andrej S wrote:
>>> Hallo, Dmitry!
>>> 17, 31)
>>> 17, 31)
>>> Regards
>>> Andrej
>>>>>> edge1
>>>>>> ! attr1 !
>>>>>> Andrej S wrote:
>>>>>>> Hi, Dmitry!
>>>>>>> ecore snip:
>>>>>>> </eClassifiers>
>>>>>>> that it
>>>>>>> looks like
>>>>>>> edge1
>>>>>>> ! attr1 !
>>>>>>> Regards
>>>>>>> Andrej
Re: Note-like labels for connections [message #133045 is a reply to message #133019] Wed, 06 June 2007 06:41 Go to previous messageGo to next message
Is there no way to create several figures (not only labels) that belongs
through a reference or a containment relation to an edge, and connect
figures to the edge with a link?
Re: Note-like labels for connections [message #133083 is a reply to message #133045] Wed, 06 June 2007 08:22 Go to previous messageGo to next message
I could recommend two strategies:
1. Define node instead of link; add two reference-based links to connect
the node with source and target.
2. Define additional node and link that connects the node with the
original link.
Re: Note-like labels for connections [message #135556 is a reply to message #133083] Wed, 13 June 2007 06:59 Go to previous message
I tried and failed with the second alternative, before I post in the
news group. I defined a node with a reference to a edge, but didn't
wangle mapping. How can a link be created, based on a reference?
> original link.
Previous Topic:compartment problem (bis)
Next Topic:Default int value doesn't appear
Current Time: Wed Jul 23 04:05:09 EDT 2025
Powered by FUDForum. Page generated in 0.51089 seconds
