Home » Eclipse Projects » GEF » Perplexing trouble in importing packages
Perplexing trouble in importing packages [message #124874] Tue, 30 March 2004 02:51 Go to next message
Originally posted by: rbhatna.clemson.edu
I am trying to create a plugin on thh lines of the paint plugin which is
available as an example.
My problem is that i get compilation errors on import statements -
import org.eclipse.ui.part;
import org.eclipse.ui.plugin;
the error statements are of the type "the import org.eclipse.ui.plugin
cannot be resolved"
I was able to remove similar errors in importing org.eclipse.jface.action.*
and org.eclipse.jface.action.resource.* by simply adding the library
(jface.jar) to the project.
However the trouble in doing the same to the two files above is that there
is no package called org.eclipse.ui.part.* or import
org.eclipse.ui.plugin.* in the eclipse plugins directory.what reference do
I give for the two files then.
I DID add org.eclipse.ui.jar to the project but that has not worked.
There is a lot of documentation about the two packages on the internet but
no directions on how I can download them.
Could some please help.Thanks
Re: Perplexing trouble in importing packages [message #124887 is a reply to message #124874] Tue, 30 March 2004 10:44 Go to previous messageGo to next message
These are eclipse plugins that ship with eclipse. The jar may not mirror the
path of the import. You may want to search through the various
org.eclipse.ui plugin folders to find the jar you need. For example, the
package might be contained in the workbench.jar in the ui.workbench folder.
"Rahul" <rbhatna@clemson.edu> wrote in message
news:c4b8uo$mfq$1@eclipse.org...
> cannot be resolved"
Re: Perplexing trouble in importing packages [message #124975 is a reply to message #124887] Tue, 30 March 2004 21:52 Go to previous message
Bingo! I added jar files in ui.win32 and ui.workbench and it worked.Thank
you.
> > cannot be resolved"
Previous Topic:GEF + RCP + org.eclipse.ui.editors
Next Topic:loss of focus on drag and drop from palette
Current Time: Sat Nov 22 18:31:23 EST 2025
Powered by FUDForum. Page generated in 0.03509 seconds
