Home » Language IDEs » ServerTools (WTP) » can't launch JBoss 3.2.3 as a Generic server in WTP 0.7RC1 w/Eclipse3.1
can't launch JBoss 3.2.3 as a Generic server in WTP 0.7RC1 w/Eclipse3.1 [message #124789] Fri, 22 July 2005 11:04 Go to next message
Originally posted by: vrana.vestmark.com
I've configured a generic launch within WTP 0.7RC1 and Eclipse 3.1 for =
launching my app from within JBoss3.2.3. When I launch the server from =
within WTP,
JBoss and my app go through their normal annunciation sequence, includin=
g =
the obligatory "JBoss (MX MicroKernel) [3.2.3 (build: CVSTag=3DJBoss_3_=
2_3 =
date=3D200311301445)] Started in 1m:35s:440ms" message. However, after a=
minute or so, WTP decides that the server failed to start and kills the =
process.
Anyone seen an issue similar to this before or have ideas on how to =
troubleshoot/fix this issue?
thanks,
Vik
Re: can't launch JBoss 3.2.3 as a Generic server in WTP 0.7RC1 w/Eclipse3.1 [message #124826 is a reply to message #124789] Fri, 22 July 2005 11:16 Go to previous messageGo to next message
Originally posted by: gercan.removeThis.acm.org
Vik,
I suspect the port your server is set to start and the port you
configure wtp to query if server started does not match. Can you check
that they match?
Gorkem Ercan
vrana@vestmark.com wrote:
> within WTP,
> including the obligatory "JBoss (MX MicroKernel) [3.2.3 (build:
> CVSTag=JBoss_3_2_3 date=200311301445)] Started in 1m:35s:440ms"
> message. However, after a minute or so, WTP decides that the server
> failed to start and kills the process.
> thanks,
> Vik
Re: can't launch JBoss 3.2.3 as a Generic server in WTP 0.7RC1 w/Eclipse3.1 [message #124838 is a reply to message #124826] Fri, 22 July 2005 11:30 Go to previous messageGo to next message
Hi Gorkem,
That sounds like a likely culprit. I'm somewhat ingenuous when it comes =
to =
WTP config files, any idea where the configuration
for the query port parameter is stored? Is the query port the same as th=
e =
http port? I have my JBoss server's http port set to 8080, the same thin=
g =
as the "port" property in the jboss323.serverdef file, viz below, but it=
doesn't seem to help.
<property id=3D"port"
label=3D"%serverPort"
type=3D"string"
context=3D"server"
default=3D"8080" />
thanks,
Vik
On Fri, 22 Jul 2005 18:16:51 +0300, Gorkem Ercan =
<gercan@removeThis.acm.org> wrote:
> Vik,
> I suspect the port your server is set to start and the port you =
> configure wtp to query if server started does not match. Can you check=
> that they match?
> Gorkem Ercan
>> I've configured a generic launch within WTP 0.7RC1 and Eclipse 3.1 fo=
r =
>> launching my app from within JBoss3.2.3. When I launch the server fro=
m =
>> within WTP,
>> JBoss and my app go through their normal annunciation sequence, =
>> including the obligatory "JBoss (MX MicroKernel) [3.2.3 (build: =
>> CVSTag=3DJBoss_3_2_3 date=3D200311301445)] Started in 1m:35s:440ms" =
>> message. However, after a minute or so, WTP decides that the server =
>> thanks,
>> Vik
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: can't launch JBoss 3.2.3 as a Generic server in WTP 0.7RC1 w/Eclipse3.1 [message #125618 is a reply to message #124838] Mon, 25 July 2005 18:58 Go to previous message
the query port is the http port. You should choose the same port as your
server configuration.
Gorkem Ercan
> Hi Gorkem,
> to WTP config files, any idea where the configuration
> the http port? I have my JBoss server's http port set to 8080, the same
> thing as the "port" property in the jboss323.serverdef file, viz below,
> but it doesn't seem to help.
> <property id="port"
> label="%serverPort"
> type="string"
> context="server"
> default="8080" />
> thanks,
> Vik
>> Vik,
>> check that they match?
>> Gorkem Ercan
>>> Hi,
>>> for launching my app from within JBoss3.2.3. When I launch the
>>> server from within WTP,
>>> to troubleshoot/fix this issue?
>>> thanks,
>>> Vik
Previous Topic:JSP standard actions
Next Topic:Welcome to the Jave Server Faces project..
Current Time: Tue Jul 22 19:47:01 EDT 2025
Powered by FUDForum. Page generated in 0.04405 seconds
