Home » Archived » BPMN Modeler » Change Labels of PopupBar
Change Labels of PopupBar [message #11409] Wed, 22 April 2009 04:06 Go to next message
I'm trying to change the labels of the popupbar - I'm not sure wether this
is the correct name. I mean the kind-of-contextmenu-thing that appears
after dragging a connection. I need to change the labels of the entries
there - is there any chance to do that?
In the same context I need to change the ToolTips of the other "Tool" that
provides the graphical views of the available elementtypes (I also do not
know a name for that) and appears on CTRL+Space.
Thanks for help,
--Verena
Re: Change Labels of PopupBar [message #11446 is a reply to message #11409] Wed, 22 April 2009 06:53 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Verena wrote:
> this is the correct name. I mean the kind-of-contextmenu-thing that
> appears after dragging a connection. I need to change the labels of the
> entries there - is there any chance to do that?
It's a PopupMenuCommand showing a list of IElementType for you to pick one.
You need to hack the ConnectionAndEndLabelProviderEx in the
PromptForConnectionAndEndCommandEx class that is used in the
PromptForConnectionAndEndCommandEx edit policy.
Best to extend ContainerNodeEditPolicyEx, override
getPromptForConnectionAndEndCommand and return there your own command
with your hacked label provider.
> that provides the graphical views of the available elementtypes (I also
> do not know a name for that) and appears on CTRL+Space.
That's named the popup bar. You need to override PopupBarEditPolicyEx
and look at the populatePopupBars method.
Antoine
Re: Change Labels of PopupBar [message #11483 is a reply to message #11446] Wed, 22 April 2009 10:43 Go to previous messageGo to next message
Antoine Toulme wrote:
> Verena wrote:
I tried that, but it is never called. Do I need to 'register' that
somewhere?
This one goes the same - never called. I'd probably have to do something
to tell the 'Framework' that this one should be used, but I have no idea
where.
Thanks gaain for your help.
Re: Change Labels of PopupBar [message #11520 is a reply to message #11483] Wed, 22 April 2009 17:32 Go to previous messageGo to next message
Do a Ctrl+Shift+G on ContainerNodeEditPolicyEx to see where it is used:
in the edit parts when they create their edit policies. Same for
PopupBarEditPolicyEx.
That's where you hook them up.
Antoine
>> Verena wrote:
>>> Hi,
>> one.
> somewhere?
> where.
Re: Change Labels of PopupBar [message #11556 is a reply to message #11520] Fri, 24 April 2009 02:40 Go to previous message
Thanks a lot - it works now.
Previous Topic:Deletion of Task
Next Topic:Changing the Activity name through a listener
Current Time: Sun Nov 09 08:13:34 EST 2025
Powered by FUDForum. Page generated in 0.03540 seconds
