Home » Language IDEs » ServerTools (WTP) » Entity Beans support by WTP
Entity Beans support by WTP [message #124641] Fri, 22 July 2005 07:00 Go to next message
Originally posted by: thmwg.web.de
Hello together,
iŽve got one question. IŽve installed eclipse wtp correctly and everything
works. But I miss the support of Generating Entity Beans (BMP, CMP) by
WTP. With eclipse and lomboz I was able to generate BMP and CMP but I
canŽt find something like that in wtp. Is this not supported. If yes, is
there a plugin which supports this and works together with WTP?
Thanks for help.
Greeting
Thomas
Re: Entity Beans support by WTP [message #124802 is a reply to message #124641] Fri, 22 July 2005 11:07 Go to previous messageGo to next message
Originally posted by: gercan.removeThis.acm.org
If you are looking for any entity bean wizards like those in Lomboz,
these are not available in WTP. But you can have your entity beans
generated with xdoclet builder in WTP.
Gorkem Ercan
Thomas Wagner wrote:
> Hello together,
> everything works. But I miss the support of Generating Entity Beans
> (BMP, CMP) by WTP. With eclipse and lomboz I was able to generate BMP
> and CMP but I canŽt find something like that in wtp. Is this not
> supported. If yes, is there a plugin which supports this and works
> together with WTP?
> Thanks for help.
> Greeting
> Thomas
Re: Entity Beans support by WTP [message #132882 is a reply to message #124802] Mon, 15 August 2005 15:03 Go to previous message
> Gorkem Ercan
>> Hello together,
>> together with WTP?
>> Thanks for help.
>> Greeting
>> Thomas
the wizard for entity bean will be available in a next version (as
session or message driven beans) ?
Previous Topic:CVS in .deployables
Next Topic:trouble with jsp tags
Current Time: Thu Nov 20 14:26:55 EST 2025
Powered by FUDForum. Page generated in 0.22976 seconds
