Home » Language IDEs » C / C++ IDE (CDT) » variable names not appearing
| variable names not appearing [message #124613] |
Thu, 21 October 2004 13:52  |
Originally posted by: ward.mcqueen.intel.com
When I am in debug mode, the Variables window is showing only the small
blue triangles followed by 3 dots. If I double click a triangle it brings
up the variable name with its value. Any idea how I can get the variable
names to display?
| Re: variable names not appearing [message #124637 is a reply to message #124625] |
Thu, 21 October 2004 16:33   |
Mikhail Khodjaiants wrote:
> Can you please post your .log file?
> "Ward McQueen" <ward.mcqueen@intel.com> wrote in message
> news:cl8t14$si5$1@eclipse.org...
> > names to display?
!SESSION Oct 20, 2004 17:09:10.291
eclipse.buildId=M200409161125
java.fullversion=J2RE 1.4.1 IBM build cxia321411-20040301 (JIT enabled:
jitc)
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:09:10.291
!MESSAGE Internal error logged from CDI Debug:
!STACK 0
org.eclipse.cdt.debug.core.cdi.CDIException: No stack.
org.eclipse.cdt.debug.mi.core.cdi.model.Target.getCThreads(T arget.java:291)
org.eclipse.cdt.debug.mi.core.cdi.model.Target.getThreads(Ta rget.java:315)
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.refre shThreads(CDebugTarget.java:713)
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.handl eSuspendedEvent(CDebugTarget.java:1334)
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.handl eDebugEvents(CDebugTarget.java:1049)
org.eclipse.cdt.debug.mi.core.cdi.EventManager.fireEvents(Ev entManager.java:245)
org.eclipse.cdt.debug.mi.core.cdi.EventManager.update(EventM anager.java:216)
at java.util.Observable.notifyObservers(Observable.java(Compile d Code))
org.eclipse.cdt.debug.mi.core.MISession.notifyObservers(MISe ssion.java:492)
at org.eclipse.cdt.debug.mi.core.EventThread.run(EventThread.ja va:46)
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:09:10.296
!STACK 0
org.eclipse.cdt.debug.mi.core.cdi.model.Target.getCurrentThr ead(Target.java:300)
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.setCu rrentThread(CDebugTarget.java:1739)
org.eclipse.cdt.debug.internal.core.model.CDebugTarget.refre shThreads(CDebugTarget.java:749)
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:09:48.612
!MESSAGE Not a CDT breakpoint
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:10:06.222
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:11:07.962
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:13:21.109
!STACK 0
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:13:21.179
!STACK 0
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:13:25.774
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:13:51.628
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:14:50.364
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:17:14.121
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:18:12.377
!STACK 0
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:18:12.379
!STACK 0
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:21:33.148
!ENTRY org.eclipse.debug.core 4 120 Oct 20, 2004 17:21:37.410
!MESSAGE Error logged from Debug Core:
!STACK 0
java.io.IOException: close error
org.eclipse.cdt.utils.pty.PTYOutputStream.close(PTYOutputStr eam.java:71)
org.eclipse.debug.internal.core.InputStreamMonitor.write(Inp utStreamMonitor.java:102)
org.eclipse.debug.internal.core.InputStreamMonitor$1.run(Inp utStreamMonitor.java:75)
at java.lang.Thread.run(Thread.java:568)
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:21:37.412
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:23:02.333
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:27:44.100
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:27:44.102
!MESSAGE Breakpoint does not have an associated marker.
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:32:02.709
!STACK 0
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:32:02.711
!STACK 0
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 20, 2004 17:32:07.768
!MESSAGE {R,T}xThread terminated
!ENTRY org.eclipse.cdt.launch 4 104 Oct 21, 2004 10:04:34.66
!MESSAGE Program file does not exist
!STACK 0
java.io.FileNotFoundException:
/home/dev/eclipse/eclipse/workspace/bel1/a.out not found
org.eclipse.cdt.launch.AbstractCLaunchDelegate.getProgramFil e(AbstractCLaunchDelegate.java:450)
org.eclipse.cdt.launch.internal.LocalCLaunchConfigurationDel egate.launch(LocalCLaunchConfigurationDelegate.java:69)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:569)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:788)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:955)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!SUBENTRY 1 org.eclipse.cdt.launch 4 104 Oct 21, 2004 10:04:34.67
!MESSAGE /home/dev/eclipse/eclipse/workspace/bel1/a.out not found
!STACK 0
!ENTRY org.eclipse.core.runtime 4 2 Oct 21, 2004 10:10:40.275
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.ClassCastException: org.eclipse.compare.internal.CompareEditor
org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineAction Delegate.canPerformAction(ResumeAtLineActionDelegate.java:22 4)
org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineAction Delegate.update(ResumeAtLineActionDelegate.java:166)
org.eclipse.cdt.debug.internal.ui.actions.ResumeAtLineAction Delegate.partActivated(ResumeAtLineActionDelegate.java:130)
org.eclipse.ui.internal.PartListenerList$1.run(PartListenerL ist.java(Inlined
Compiled Code))
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java(Inlined
Compiled Code))
at org.eclipse.core.runtime.Platform.run(Platform.java(Inlined Compiled
Code))
org.eclipse.ui.internal.PartListenerList.firePartActivated(P artListenerList.java(Compiled
Code))
org.eclipse.ui.internal.WWinPartService.firePartActivated(WW inPartService.java:181)
org.eclipse.ui.internal.WWinPartService.access$0(WWinPartSer vice.java:178)
org.eclipse.ui.internal.WWinPartService$1.partActivated(WWin PartService.java:25)
org.eclipse.ui.internal.PartListenerList2$1.run(PartListener List2.java:45)
Compiled Code))
at org.eclipse.core.runtime.Platform.run(Platform.java(Compiled Code))
org.eclipse.ui.internal.PartListenerList2.firePartActivated( PartListenerList2.java:43)
org.eclipse.ui.internal.WorkbenchPage.firePartActivated(Work benchPage.java:1371)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:2738)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:2415)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:304)
org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:127)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:325)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 154)
org.eclipse.ui.internal.PartStack.presentationSelectionChang ed(PartStack.java:677)
at org.eclipse.ui.internal.PartStack.access$0(PartStack.java:66 0)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.jav a:94)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.setSelection(DefaultPartPresentation.java:1408)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n$4.handleEvent(DefaultPartPresentation.java:166)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java (Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Inlined Compiled
Code))
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java(Compile d Code))
Code))
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java(C ompiled
Code))
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.ja va(Inlined
Compiled Code))
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java(Co mpiled
Code))
org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.j ava(Compiled
Code))
Code))
Code))
org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va(Compiled
Code))
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java (Compiled
Code))
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a(Compiled
Code))
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:79)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:41)
at java.lang.reflect.Method.invoke(Method.java:386)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.debug.core 4 120 Oct 21, 2004 11:05:15.356
!STACK 0
java.io.IOException: Target is not responding (timed out)
org.eclipse.cdt.debug.mi.core.SessionProcess$1.post(SessionP rocess.java:83)
org.eclipse.cdt.debug.mi.core.SessionProcess$1.write(Session Process.java:68)
at java.io.OutputStream.write(OutputStream.java:113)
at java.io.OutputStream.write(OutputStream.java(Compiled Code))
org.eclipse.debug.internal.core.InputStreamMonitor.writeNext (InputStreamMonitor.java:116)
org.eclipse.debug.internal.core.InputStreamMonitor.write(Inp utStreamMonitor.java:99)
!ENTRY org.eclipse.cdt.debug.core 4 1000 Oct 21, 2004 11:05:15.362
| Re: variable names not appearing [message #124733 is a reply to message #124637] |
Fri, 22 October 2004 13:13  |
Nevermind, I restarted eclipse and they are appearing now (this is my
first time using it :))
Thanks!
> > > names to display?
> jitc)
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> Compiled Code))
> at
> Compiled Code))
> Code))
> at
> Code))
> at
> at
> at
> at
> at
> Compiled Code))
> at
> at
> at
> at
> at
> at
> at
> at
> Code))
> Code))
> Code))
> Code))
> Compiled Code))
> Code))
> at
> Code))
> Code))
> Code))
> at
> Code))
> Code))
> Code))
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
> at
Current Time: Sun Nov 09 23:05:15 EST 2025
Powered by FUDForum. Page generated in 0.04008 seconds
