Home » Eclipse Projects » GEF » Is it possible to make a Blinking Element?
Is it possible to make a Blinking Element? [message #124570] Fri, 26 March 2004 12:57 Go to next message
I want to make an element which blinks at every 2 seconds, and I have
developed a class - BlinkControler, which notifies the model when to
blink.
The model the calls firePropertyChange(...) and updates the figure. To
make
the delay of 2 seconds I make a new thread and use Thread.sleep(2000).
After
thah I call BlinkControler.listeners.firePropertyChange(...) which
notifies
the model. At least this is the idea.
My model is a listener in the BlinkControler class. BlinkControler
implements
Runnable and I use theads. But when the BlinkControler notifies the model
an
exception is thrown. Here is the information which appears in the console
view:
org.eclipse.draw2d.DeferredUpdateManager.queueWork(DeferredU pdateManager.java:146)
org.eclipse.draw2d.DeferredUpdateManager.addInvalidFigure(De ferredUpdateManager.java:96)
at org.eclipse.draw2d.Figure.revalidate(Figure.java:1210)
at org.eclipse.draw2d.Figure.revalidate(Figure.java:1212)
org.eclipse.geditor.editparts.ElementEditPart.propertyChange (ElementEditPart.java:39)
java.beans.PropertyChangeSupport.firePropertyChange(Property ChangeSupport.java:252)
org.eclipse.geditor.models.Element.firePropertyChange(Elemen t.java:32)
org.eclipse.geditor.models.BlinkingElement.propertyChange(Bl inkingElement.java:143)
org.eclipse.geditor.models.BlinkControler.run(BlinkControler .java:42)
Could somebody help me?
Thank you.
Re: Is it possible to make a Blinking Element? [message #124606 is a reply to message #124570] Fri, 26 March 2004 16:02 Go to previous messageGo to next message
GEF is not thread safe. Make sure you only call methods on the UI thread.
Why not use Display.timerExec(2000, new Runnable(){...});?
"kiko" <kiril_mitov@abv.bg> wrote in message
news:c41qus$cpa$1@eclipse.org...
> blink.
> make
> After
> notifies
> implements
> an
> view:
> java.lang.NullPointerException
> at
a:146)
> at
ger.java:96)
> at
..java:39)
> at
va:252)
> at
> at
va:143)
> at
va:252)
> at
> Thank you.
Re: Is it possible to make a Blinking Element? [message #124715 is a reply to message #124606] Sat, 27 March 2004 20:04 Go to previous messageGo to next message
Originally posted by: news_reply.lindeijer.nl
I had the same problem, and found a solution you may find usefull.
The NullPointerException is caused within DeferredUpdateManager.queueWork
because Display.getCurrent() returns null for the current UI display. This
is probably because the BlinkControler.run thread you start is not a UI
thread.
Anyway, what I did was aquire a reference to the current Display some other
way, and then used Randy Hudsons solution regarding thread safety.
The change in my model, which originated via rmi from some other remote
process, eventually invokes a method called propertyChange on the model's
EditPart. This pattern is copied from the GEF examples. First thing this
method does in call
this.display = this.getRoot().getViewer().getControl().getDisplay();
aquiring a reference to its Display. Next, the Runnable is executed
asynchronously.
this.display.asyncExec(
new Runnable() { public void run() { refreshVisuals(); } }
Hopes it works for you also. It would make the time I wasted figuring this
out more worthwhile.
David.
Re: Is it possible to make a Blinking Element? [message #124752 is a reply to message #124715] Sun, 28 March 2004 14:32 Go to previous messageGo to next message
Thank you David!
I did it as you said. But it does not work. The problem is that after I
call
the method MyFigure::paintFigure(Graphics g) isn`t called. So my figure
isn`t
repainted. Do you have any idea why MyFigure::paintFigure(...) isn`t
called ?
kiko
> thread.
> method does in call
> asynchronously.
> Cheers,
> David.
Re: Is it possible to make a Blinking Element? [message #124763 is a reply to message #124752] Sun, 28 March 2004 16:01 Go to previous messageGo to next message
You'd have to tell us what refreshVisuals() does, and all of the code for
any methods it calls which you wrote.
news:c4798d$a6d$1@eclipse.org...
> Thank you David!
> call
> isn`t
> called ?
> kiko
This
> > thread.
other
model's
> > method does in call
> > asynchronously.
this
> > Cheers,
> > David.
Re: Is it possible to make a Blinking Element? [message #124775 is a reply to message #124763] Sun, 28 March 2004 16:25 Go to previous messageGo to next message
Here is the code of my BlinkElementEditPart::propertyChange(...):
public void propertyChange(java.beans.PropertyChangeEvent change){
if ( change.getPropertyName().equals(BlinkElement.BLINK))
new Runnable() {
public void run() {
refreshVisuals();
else
super.propertyChange(change);
Here is the code of refreshVisuals():
protected void refreshVisuals() {
getBlinkElementFigure().setCurrentColor(
getBlinkElementModel().getCurrentColor());
Point loc = getRelsaSubpart().getLocation();
Dimension size= getRelsaSubpart().getSize();
Rectangle r = new Rectangle(loc ,size);
((GraphicalEditPart) getParent()).setLayoutConstraint(this, getFigure(),
r);
My stucture is similar to the structure of the Logic example so here
RelsaSubpart is very similar to LogicSubpart(there aren`t any
differences).
The BlinkControler changes the currentColor in the BlinkElement. When the
BlinkElementEditPart refreshes it visuals, it sets the figure color. -
getBlinkElementFigure().setCurrentColor(...);
The problem is than BlinkElementFigure::paintGraphics(...) isn`t called.
Thank you.
kiko
> > Thank you David!
> > call
> > isn`t
> > called ?
> > kiko
> This
> > > thread.
> other
> model's
this
> > > method does in call
> > > asynchronously.
> this
> > > Cheers,
> > > David.
Re: Is it possible to make a Blinking Element? [message #125597 is a reply to message #124775] Fri, 02 April 2004 11:44 Go to previous messageGo to next message
You mean BlinkElementFigure::paint(Graphics)? You probably only need to
override the paintFigure method, and not the paint method.
What does BlinkElementFigure.setCurrentColor(Color) do? Does it revalidate
the figure?
news:c47ft4$ga1$1@eclipse.org...
> new Runnable() {
> public void run() {
> refreshVisuals();
> else
> r);
> differences).
> Thank you.
> kiko
for
> > > Thank you David!
I
> > > call
figure
> > > isn`t
> > > called ?
> > > kiko
display.
> > This
UI
> > > > thread.
some
> > other
remote
> > model's
> this
> > > > method does in call
> > > > asynchronously.
figuring
> > this
> > > > Cheers,
> > > > David.
Re: Is it possible to make a Blinking Element? [message #125813 is a reply to message #125597] Mon, 05 April 2004 13:11 Go to previous messageGo to next message
I think i fixed the problem. I don't know whether it is right but i call
revalidate() in the refreshVisual().
For now it works for me.
Thank you all for your help.
kiko
> the figure?
> > new Runnable() {
> > public void run() {
> > refreshVisuals();
> > else
getFigure(),
> > r);
> > differences).
> > Thank you.
> > kiko
> for
> > > > Thank you David!
> I
> > > > call
> figure
> > > > isn`t
> > > > called ?
> > > > kiko
> display.
> > > This
a
> UI
> > > > > thread.
> some
> > > other
> remote
> > > model's
> > this
> > > > > method does in call
> > > > > this.display =
> > > > > asynchronously.
> figuring
> > > this
> > > > > Cheers,
> > > > > David.
Re: Is it possible to make a Blinking Element? [message #126153 is a reply to message #125813] Tue, 06 April 2004 10:47 Go to previous message
You shouldn't call revalidate() unless you want to layout. Calling
revalidate does not guarantee a repaint.
news:c4s3vf$7dt$1@eclipse.org...
> kiko
called.
revalidate
> > the figure?
> > > new Runnable() {
> > > public void run() {
> > > refreshVisuals();
> > > else
> getFigure(),
> > > r);
> > > differences).
the
called.
> > > Thank you.
> > > kiko
code
> > for
> > > > > Thank you David!
after
> > I
> > > > > call
> > figure
> > > > > isn`t
isn`t
> > > > > called ?
> > > > > kiko
usefull.
> > display.
> > > > This
not
> a
> > UI
> > > > > > thread.
> > some
> > > > other
safety.
> > remote
the
> > > > model's
thing
> > > this
> > > > > > method does in call
> > > > > > this.display =
executed
> > > > > > asynchronously.
> > figuring
> > > > this
> > > > > > Cheers,
> > > > > > David.
Previous Topic:Extension point for adding tool entry
Next Topic:Differneces between 2.1.2 and 2.1.3
Current Time: Sun Nov 09 00:10:17 EST 2025
Powered by FUDForum. Page generated in 0.04216 seconds
