Home » Eclipse Projects » Equinox » Equinox Transforms
Equinox Transforms [message #124019] Thu, 08 January 2009 13:45 Go to next message
Originally posted by: kathir.atc.tcs.com
I tried running the xslt example plugin from my eclipse. I get the following
exception when i used the launch file inside the xslt plugin.
java.lang.ClassNotFoundException:
org.eclipse.core.runtime.adaptor.EclipseStarter
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 546)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
2.
I created my own transforms and used it in my application plugin to filter
some extensions. I added a startup handler exception to check whether the
transforms are applied or not. Whenever i start the app, the startup handler
extension will be removed and i should be able to see the application. But
whatever way i try to launch, the transform doesnt get applied and the
startup handler gets invoked.
How do i run the transforms based application from inside eclipse. I have
osgi.framework.extensions attribute set in my run configurations.
When i export the application as a product, the transformations get applied
and the startup handler is removed from the extensions.
3. So i am exporting the product everytime i make changes to my code and
testing it. The next problem is I do a login when i start the application.
The Login Dialog uses jface classes for the UI. I do the login check before
i do the transforms. I get ClassNotFoundException for all the jface classes
from inside the transforms fragment. Is it possible to use any eclipse
plugin classes before i do the transforms.
PS: I used the sample from Bredex authorization and extending it to my
needs.
Am i doing things on the right direction. Any suggestions?
Kathir.
Re: Equinox Transforms [message #124034 is a reply to message #124019] Thu, 08 January 2009 14:03 Go to previous messageGo to next message
I got the xslt working. Just didn't do the "add required plugins" before
launching it.
Any suggestions for 2 & 3 ?
Kathir."news.eclipse.org" <kathir@atc.tcs.com> wrote in message
news:gk5hka$pl$1@build.eclipse.org...
> 1.
> following exception when i used the launch file inside the xslt plugin.
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> 2.
> handler extension will be removed and i should be able to see the
> application. But whatever way i try to launch, the transform doesnt get
> applied and the startup handler gets invoked.
> applied and the startup handler is removed from the extensions.
> before i do the transforms. I get ClassNotFoundException for all the jface
> classes from inside the transforms fragment. Is it possible to use any
> eclipse plugin classes before i do the transforms.
> needs.
> Kathir.
Re: Equinox Transforms [message #124047 is a reply to message #124034] Thu, 08 January 2009 14:09 Go to previous messageGo to next message
Here are the plugin structure i have.
1. com.comp.product.transforms
2. com.comp.product.diagnostics
diagnostics does a login and based on the permissions of the user,
extensions are filtered. The filtering is done in the transforms fragment.
Kathir.
news:gk5ilu$kfp$1@build.eclipse.org...
> launching it.
>> 1.
>> 2.
>> filter some extensions. I added a startup handler exception to check
>> whether the transforms are applied or not. Whenever i start the app, the
>> startup handler extension will be removed and i should be able to see the
>> application. The Login Dialog uses jface classes for the UI. I do the
>> login check before i do the transforms. I get ClassNotFoundException for
>> all the jface classes from inside the transforms fragment. Is it possible
>> to use any eclipse plugin classes before i do the transforms.
>> needs.
>> Kathir.
Re: Equinox Transforms [message #124084 is a reply to message #124047] Thu, 08 January 2009 18:55 Go to previous messageGo to next message
2. I resolved the problem of launching it from inside eclipse, i had to
import the org.eclipse.osgi project into the workspace. Otherwise it wont
work.
But i got into a different problem now, Now i get a ClassNotFoundException
from inside the transforms extension class.
I have a PluginTransformingBundleFileWrapperFactoryHook which implements
BundleFileWrapperFactoryHook,HookConfigurator, AdaptorHook
public BundleFile wrapBundleFile(BundleFile bundleFile, Object content,
BaseData data, boolean base)
throws IOException
if (m_startLevelManager != null && m_startLevelManager.getStartLevel() >= 1)
if (m_loginClass == null)
try
ClassLoader classLoader = getClass().getClassLoader();
m_loginClass = classLoader.loadClass(m_loginProperty);
ILogin login;
System.out.println("Calling the Login module");
login = (ILogin) m_loginClass.newInstance();
// The actual rights loading from a login
// implementation.
m_rightsList = login.login();
login = null;
catch (Exception e)
e.printStackTrace();
System.err.println("RCP-Auth: Couldn't call the " + "ILogin.login
method.\nEclipse will now exit.");
// System.exit(1);
return new PluginTransformBundleFile(getContext(), data, bundleFile);
return null;
PluginTransformBundleFile.java
* Returns BundleEntry at path.
* @param path
* The file path.
* @return The original bundle entry, or a PluginTransformBundleEntry
instance.
public BundleEntry getEntry(final String path)
final BundleEntry original = m_delegate.getEntry(path);
if (m_data.getBundle() == null || path == null || original == null)
return original;
try
if (path.equals("plugin.xml"))
return new PluginTransformBundleEntry(original, original.getInputStream());
catch (IOException e)
System.err.println(this.getBundleContext() + "#" +
this.getClass().getCanonicalName() + ": "
+ "Couldn't create " + PluginTransformBundleEntry.class.getCanonicalName() +
" for file " + path);
return original;
I get a ClassNotFoundException for PluginTransformBundleEntry when i run in
debug mode. In normal mode nothing happens, it just didnt do the transform.
i
have -Dosgi.framework.extensions=com.comp.product.transforms,com. comp.product.diagnostics
in the run configurations vm arguments.
I am struck with this now.
Kathir.
"Kathir" <kathir@atc.tcs.com> wrote in message
news:gk5j13$p3n$1@build.eclipse.org...
> Kathir.
>> launching it.
>>> Hi,
>>> 1.
>>> 2.
>>> the application. But whatever way i try to launch, the transform doesnt
>>> get applied and the startup handler gets invoked.
>>> have osgi.framework.extensions attribute set in my run configurations.
>>> possible to use any eclipse plugin classes before i do the transforms.
>>> needs.
>>> Kathir.
Re: Equinox Transforms [message #124169 is a reply to message #124034] Fri, 09 January 2009 17:10 Go to previous message
> launching it.
Sorry..I got excited when i saw something running and realized it didnt
really work for me. How do i check the whether xslt example is working or
not.
Kathir.
>> 1.
>> 2.
>> needs.
>> Kathir.
Previous Topic:Dropins flaky
Next Topic:Fire Events Periodically ??
Current Time: Sat Nov 22 09:32:32 EST 2025
Powered by FUDForum. Page generated in 0.04830 seconds
