Home » Language IDEs » Java Development Tools (JDT) » Refactoring: add new refactoring
Refactoring: add new refactoring [message #124002] Wed, 03 December 2003 04:06 Go to next message
Originally posted by: scheglov_ke.nlmk.ru
We need to add new refactoring for out project. I know that refactoring API
is currently internal, but I want to clarify for myself several quiestions.
1. Will refactoring become public API in 3.0?
2. How to add new refactoring in "Refactor" menu? I want to show refactoring
action only when my editor is active, so I add it as editorActions and set
menubarPath as for other actions in JDT UI plugin.xml:
"org.eclipse.jdt.ui.refactoring.menu/reorgGroup" But Eclipse complains that
such menu path does not exist. So is it possible at all?
Here is full extention:
<extension
point="org.eclipse.ui.editorActions">
<editorContribution
targetID="com.swtdesigner.editors.MultiPageEditor"
id="org.eclipse.ui.texteditor.ruler.actions">
<action
definitionId="com.swtdesigner.refactoring.extract.frame.action "
label="Extract Frame"
class="com.swtdesigner.refactoring.ExtractFrameAction"
menubarPath="org.eclipse.jdt.ui.refactoring.menu/reorgGroup "
id="com.swtdesigner.refactoring.ExtractFrameAction">
</action>
</editorContribution>
</extension>
3. Most probably here is not right place to ask this question, but just to
ask all of them... Refactoring action should be enabled not just when me editor
is active, but also when some conditions are satisfied, so I try to use setEnabled()
method, but menu item is enabled always, even when I call setEnabled(false).
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Refactoring: add new refactoring [message #127507 is a reply to message #124002] Mon, 15 December 2003 13:32 Go to previous messageGo to next message
From what I understand in to JDT UI plan, the refactoring API will be
opened up. (see http://www.eclipse.org/jdt/index.html, go to "UI", then
in "What's happening" go to "plan").
> API
> quiestions.
> refactoring action only when my editor is active, so I add it as
> editorActions and set menubarPath as for other actions in JDT UI
> plugin.xml: "org.eclipse.jdt.ui.refactoring.menu/reorgGroup" But Eclipse
> complains that such menu path does not exist. So is it possible at all?
> <extension
> <editorContribution
> <action
> </action>
> </extension>
> editor is active, but also when some conditions are satisfied, so I try to
> use setEnabled() method, but menu item is enabled always, even when I call
> setEnabled(false).
Re: Refactoring: add new refactoring [message #128683 is a reply to message #127507] Fri, 19 December 2003 05:42 Go to previous message
A little late, but the reason why the action doesn't show up in the
context menu of the editor is, that you have to redefine the menu.
Here an example for a new refactoring action as an object contribution
and a contribution to a editor's context menu.
<extension point="org.eclipse.ui.popupMenus">
<viewerContribution
id="myId"
targetID="#CompilationUnitEditorContext">
<menu
id="org.eclipse.jdt.ui.refactoring.menu"
label="Refactor"
path="additions">
<separator name="undoRedoGroup"/>
<separator name="reorgGroup"/>
<separator name="typeGroup"/>
<separator name="codingGroup"/>
<separator name="myGroup"/>
</menu>
<action
id="myRefactoring"
label="My Refactoring"
menubarPath="org.eclipse.jdt.ui.refactoring.menu/myGroup"
class="MyClass">
</action>
</viewerContribution>
<objectContribution
id="watson"
objectClass="org.eclipse.jdt.core.IType">
<menu
label="Refactor"
path="additions">
</menu>
<action
id="myRefactoring"
class="MyClass">
</action>
</objectContribution>
</extension>
"Guillaume Pothier" <gpothier@free.fr> wrote in message
news:pan.2003.12.15.18.32.21.107224@free.fr...
refactoring
> > API
> > quiestions.
> > <extension
> > <editorContribution
> > <action
> > </action>
> > </extension>
to
to
call
> > setEnabled(false).
Previous Topic:Step Filtering
Next Topic:my plug-in crashes IDE
Current Time: Sat Jul 26 13:16:31 EDT 2025
Powered by FUDForum. Page generated in 0.04645 seconds
