Home » Language IDEs » ServerTools (WTP) » Problem with escaped Strings in JSP Tags
Problem with escaped Strings in JSP Tags [message #123865] Thu, 21 July 2005 03:12 Go to next message
Hi all,
I have problems with a lot of JSPs with tags that contain values with
escaped strings like <xxx:sometag name="name" value="<%= (String)
request.getParameter(\"parametername\")"/>
I allway get the error message "Syntax Error on token "Invalid Character",
invalid Expression" where the backslash used to escape the quotes is tagged
as the invalid character.
This errors occures in Eclipse 3.1 with WTP 0.7RC1 and earlier versions as
well, but the JSPs work cause no problems in the application server.
Klaus
Re: Problem with escaped Strings in JSP Tags [message #124377 is a reply to message #123865] Thu, 21 July 2005 19:14 Go to previous messageGo to next message
Please open bug reports for problems like these.
http://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20Too ls&component=jst.jsp
- Nitin
Re: Problem with escaped Strings in JSP Tags [message #124416 is a reply to message #124377] Thu, 21 July 2005 19:26 Go to previous messageGo to next message
Originally posted by: thisisnot.mymail.com
I think you could use EL to insert params that should at least let you
do your work.
>> Character",
>> tagged
>> versions as
Re: Problem with escaped Strings in JSP Tags [message #124529 is a reply to message #124416] Fri, 22 July 2005 03:49 Go to previous message
Thanks for your answers, I opened a bug report for that
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=104767).
Using EL might be a solution for new JSPs, but our project contains about
6000 JSPs where about 1000 of them are affected by this bug, but it is only
a minor inconvenience. But the requirement that the project has to be in
the workspace for a working tag completion is a blocking issue for me.
Klaus
"Srgjan Srepfler" <thisisnot@mymail.com> schrieb im Newsbeitrag
news:dbpavp$ub5$1@news.eclipse.org...
> do your work.
> >> Character",
> >> tagged
> >> versions as
Previous Topic:Problems in accessing External Web Service using WST
Next Topic:JBoss 4.0.2
Current Time: Wed Nov 05 10:44:37 EST 2025
Powered by FUDForum. Page generated in 0.15010 seconds
