Home » Archived » Memory Analyzer (MAT) » Classes from rt.jar loaded by different loaders ?
Classes from rt.jar loaded by different loaders ? [message #11331] Fri, 17 July 2009 06:06 Go to next message
This is one doubt I got into while analyzing a heap dump. I was trying to
view the classes loaded by the different class loaders, I see that system
class loader has loaded classes like java.util.HashMap etc. Then I
observed another class loader sun.misc.Launcher$AppClassLoader and there
also I see that it has references to classes java.util.HashMap. This has
led me to confusion, I always thought that if system CL is loading classes
like java.util.HashMap, it will not be loaded by any other class loader
since it is the parent CL and a class loaded by a loader can not be loaded
by its child loaders. Can you pls clarify on this please ?
Re: Classes from rt.jar loaded by different loaders ? [message #11444 is a reply to message #11331] Sun, 19 July 2009 12:05 Go to previous messageGo to next message
Satish Burnwal wrote:
> Then I
You are right - all classes from the rt.jar should be loaded using the
system class loader. What's confusing me is that you say "it has
references to classes" - of course, the another class loader can have
references to those classes, but it should not define them.
Check out the "Java Basics" -> "Class Loader Explorer". It shows all class
loaders, the classes the define and their parent class loader. I just ran
this query on two dumps and could not find any problems. Do not hesitate
to copy and paste the view to this forum to discuss.
Andreas.
Re: Classes from rt.jar loaded by different loaders ? [message #11482 is a reply to message #11444] Tue, 21 July 2009 04:26 Go to previous messageGo to next message
Andreas,
You may be right that different class loaders might reference the same
classes but I just tried to convince myself on this. Can someone tell me
when can a non-system classloader refer to a system class ? For example, I
tried to run these 2 examples and take a heap dump while the thread is
sleeping but I do not see TestCL referring to java.net.ServerSocket or
java.util.concurrent.ConcurrentLinkedQueue:
//example1
import java.net.*;
import java.util.concurrent.*;
import java.util.*;
public class TestCL extends java.lang.ClassLoader {
TestCL loader = new TestCL();
loader.load();
public void load() {
try {
String s = new String("satish");
Vector v = new Vector(10);
ServerSocket ss = new ServerSocket();
ConcurrentLinkedQueue list = new ConcurrentLinkedQueue();
System.out.println("TestCL...");
Thread.sleep(100000000);
} catch (Exception e) {
e.printStackTrace();
//example2
import java.net.*;
import java.util.*;
Thread t = new Thread(
new Runnable() {
public void run() {
try {
System.out.println("TestCL executed!!");
}, "TestThread");
t.setContextClassLoader(loader);
t.start();
try {
t.join();
Re: Classes from rt.jar loaded by different loaders ? [message #11519 is a reply to message #11482] Tue, 21 July 2009 13:51 Go to previous message
Hi Satish,
your example will not work this way - the VM knows that your are not
referencing s, v, ss, or the list after the Thread.sleep(). It will
garbage collect those items.
Probably all class loaders reference the Vector from the system class
loader.
Take this example: the class loader (not loaded by the system class loader
itself) references a hash table.
Class Name
com.foo.loader.ResourceMultiParentClassLoader @ 0xa8d6338
|- <class> class com.foo.loader.ResourceMultiParentClassLoader @ 0xe38e780
|- parent sun.misc.Launcher$AppClassLoader @ 0xa8c3710
|- package2certs java.util.Hashtable @ 0xa8d63d8
|- classes java.util.Vector @ 0xa8d6400
If you have a question how to interpret a particular view of the Memory
Analyzer, just go ahead and Ctrl-C the selected lines and copy and paste
it to the forum.
Andreas.
Previous Topic:Could not parse big heap file
Next Topic:Request for comments: MAT next steps
Current Time: Wed Nov 12 07:43:25 EST 2025
Powered by FUDForum. Page generated in 1.03555 seconds
