Home » Eclipse Projects » Equinox » Updating installed JRE question
Updating installed JRE question [message #123716] Tue, 06 January 2009 08:19 Go to next message
I would like to include JRE in our RCP-based, headlessly built product. I
plan to include the JRE as a root file of a dedicated JRE feature. That
should locate the JRE files in eclipse/JRE. But what happens when we
upgrade this feature via Software Updates to a newer version of the JRE?
Doesn't Software Updates itself use the JRE, and so could lock files or
otherwise conflict with a JRE update?
msacarny
Re: Updating installed JRE question [message #124073 is a reply to message #123716] Thu, 08 January 2009 15:00 Go to previous message
Originally posted by: eclipseng.arthorne.com
Yes, I think you'll need to run the update from another JRE. I.e., use
the director application to perform the update in a separate process,
with a separate JRE.
> I plan to include the JRE as a root file of a dedicated JRE feature.
> That should locate the JRE files in eclipse/JRE. But what happens when
> we upgrade this feature via Software Updates to a newer version of the
> JRE? Doesn't Software Updates itself use the JRE, and so could lock
> files or otherwise conflict with a JRE update?
> msacarny
Previous Topic:HttpConfiguration: change timeout by aQute fileinstall
Next Topic:Is the buddy policy working?
Current Time: Sat Nov 15 04:40:49 EST 2025
Powered by FUDForum. Page generated in 0.05159 seconds
