Home » Archived » BIRT » BIRT 2.0.0 - Web viewer shows blank page?
BIRT 2.0.0 - Web viewer shows blank page? [message #123686] Fri, 03 February 2006 09:25 Go to next message
Today I installed:
BIRT 2.0.0.under
Eclipse 3.1.1
First I want to say thanks to the devlopers, great product!
I followed the installation including the iText, Axis, etc.
I can develop a BIRT report within Eclipse, I also can use the HTML preview
and the PDF preview out of Eclipse IDE
But the Web Viewer preview opens but only shows blank page without chart.
Do I miss something?
Thanks for any help!
Re: BIRT 2.0.0 - Web viewer shows blank page? [message #123698 is a reply to message #123686] Fri, 03 February 2006 09:54 Go to previous messageGo to next message
Originally posted by: vladperl.semanticprogrammer.org
Probably you are uisng Firefox. ReportViewer in frameset mode doesn't work
in Firefox.
Re: BIRT 2.0.0 - Web viewer shows blank page? [message #123721 is a reply to message #123698] Fri, 03 February 2006 09:59 Go to previous messageGo to next message
Hello Vladimir,
no, sorry, I don't use FireFox!
I think I need to isntall the Web-Viewer apllication (Web-Viewer example)
example form the birt-runtime-2_0_0.zip first?
I tried to follow the installation under:
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php
But I don't have a directory called:
birt-viewer/plugins/org.eclipse.birt.report.engine.pdf/lib to install the
iText
And I miss further:
/birt.viewer/plugins/org.eclipse.birt.report.viewer/birt/aja x/lib to
Install the prototype.js
So I dont have the directories:
/birt-viewer/plugins/org.eclipse.birt.report.engine.pdf
I just have the folders shown in the attachment!
What should I do next? Thanks for further help!
  • Attachment: birt200.jpg
    (Size: 61.67KB, Downloaded 115 times)
Re: BIRT 2.0.0 - Web viewer shows blank page? [message #123788 is a reply to message #123721] Fri, 03 February 2006 10:35 Go to previous messageGo to next message
Now I installed the Web-Viewer successfully but the same result :-(
I can access the 1st page oft the BIRT application (see attachment 1.jpg)
after clicking 'View Example' I get the same blank page (see attachment
2.jpg) as in Eclipse IDE.
What do I miss?
  • Attachment: 1.jpg
    (Size: 48.57KB, Downloaded 115 times)
  • Attachment: 2.jpg
    (Size: 39.32KB, Downloaded 131 times)
Re: BIRT 2.0.0 - Web viewer shows blank page? [message #123815 is a reply to message #123788] Fri, 03 February 2006 10:53 Go to previous messageGo to next message
There was a typo on the deploy page on where to put the iText jar.
I just changed it.
Verify that under your Webapps/birt directory you have an ajax directory.
under the ajax directory
there should be a lib directory. In the lib directory you should have the
prototype.js file there.
Can you do a screen capture of the WEB-INF/lib directory as well?
Jason
"Mr. Burns" <Mr._Burns@web.de> wrote in message
news:drvt8i$foq$1@utils.eclipse.org...
> Hello,
> What do I miss?
Re: BIRT 2.0.0 - Web viewer shows blank page? [message #124568 is a reply to message #123815] Mon, 06 February 2006 02:44 Go to previous messageGo to next message
Hello Jason,
now it works!
If the prototyp.js resides in the .../ajax/lib directory!
Thanks!
Re: BIRT 2.0.0 - Web viewer shows blank page? [message #124593 is a reply to message #124568] Mon, 06 February 2006 02:56 Go to previous message
Originally posted by: jan.tanis.coas.com
LOL, as stated on the website!
Mr. Burns wrote:
> Hello Jason,
> now it works!
> Thanks!
Previous Topic:Pigheaded BIRT?
Next Topic:Search function does not work?
Current Time: Sun Nov 09 11:24:49 EST 2025
Powered by FUDForum. Page generated in 0.07716 seconds
