Home » Modeling » GMF (Graphical Modeling Framework) » Double click event
Double click event [message #123563] Wed, 02 May 2007 22:21 Go to next message
Originally posted by: evaandoli.dodo.com.au
Ok I've been looking around extension points all day and trying to find how
I can tap into the double click event for a Node or Node Element.
I know GMF has the Open Digram - behaviour that can be added that uses
double click so I guess it can be done.
Maybe on another note - if it is an extension point - How do you find them ?
I have farmed through in eclipse and get the descriptions but no joy.
Re: Double click event [message #123592 is a reply to message #123563] Thu, 03 May 2007 00:55 Go to previous message
Originally posted by: khai.n.situvista.com
There are many messages regarding this already but here's a summary:
In the particular EditPart that you want to handle double-click install
an EditPolicy for the OPEN_ROLE like so:
protected void createDefaultEditPolicies() {
super.createDefaultEditPolicies();
[snip...]
installEditPolicy(EditPolicyRoles.OPEN_ROLE, createOpenEditPolicy());
Then add the createOpenEditPolicy() method like so (in the same EditPart):
private OpenEditPolicy createOpenEditPolicy() {
OpenEditPolicy policy = new OpenEditPolicy() {
protected Command getOpenCommand(Request request) {
* You can create whatever command you need here
return [your command];
return policy;
That's the main idea of it.
Alternatively you can implement the EditPolicyProvider extension if you
have to install custom EditPolicies on many EditParts.
-- Khai --
Previous Topic:Opening a GMF diagram from java code
Next Topic:How to get ToolEntry for a tool ?
Current Time: Wed Nov 19 18:06:36 EST 2025
Powered by FUDForum. Page generated in 0.04880 seconds
