| FilteredItemsSelectionDialog not working [message #123548] |
Mon, 02 March 2009 11:44  |
the FilteredItemsSelectionDialog does not work as it throws an
IllegalStateException:
java.lang.IllegalStateException: No context available outside of the request
service lifecycle.
org.eclipse.rwt.internal.service.ContextProvider.getContext( ContextProvider.java:108)
org.eclipse.rwt.internal.service.ContextProvider.getSession( ContextProvider.java:146)
at org.eclipse.rwt.RWT.getLocale(RWT.java:271)
at org.eclipse.rwt.RWT$NLS.getISO8859_1Encoded(RWT.java:98)
org.eclipse.ui.internal.WorkbenchMessages.get(WorkbenchMessa ges.java:1067)
org.eclipse.ui.dialogs.FilteredItemsSelectionDialog$FilterJo b.filterContent(FilteredItemsSelectionDialog.java:2173)
org.eclipse.ui.dialogs.FilteredItemsSelectionDialog$FilterJo b.internalRun(FilteredItemsSelectionDialog.java:2121)
org.eclipse.ui.dialogs.FilteredItemsSelectionDialog$FilterJo b.doRun(FilteredItemsSelectionDialog.java:2093)
org.eclipse.ui.dialogs.FilteredItemsSelectionDialog$FilterJo b.run(FilteredItemsSelectionDialog.java:2080)
I do the following in an editor action:
FilteredItemsSelectionDialog dlg = new
MyFilteredItemsSelectionDialog(display.getActiveShell(), true);
dlg.setTitle("Mein Titel");
dlg.setInitialPattern("?");
dlg.open();
Is this a bug?
Markus
| Re: FilteredItemsSelectionDialog not working [message #123668 is a reply to message #123655] |
Tue, 03 March 2009 06:45  |
Markus,
thanks for the bug entry. I am afraid but with EclipseCon ahead I
doubt that we will be able to fix this soon.
Rüdiger
Markus Krüger wrote:
> I filed a bug: 266832
> Would be nice if this one is fixed as soon as possible, we need this very
> bad for our product.
> Markus
> "Rüdiger Herrmann" <rherrmann@eclipsesource.com> schrieb im Newsbeitrag
> news:goj2md$6jm$1@build.eclipse.org...
>> Markus,
>> you found a bug. Would you open a bugzilla?
>> TIA
>> Rüdiger
>>> Hi,
>>> request service lifecycle.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
>>> dlg.open();
>>> Is this a bug?
>>> Regards,
>>> Markus
FUDForum. Page generated in 0.10521 seconds
