Home » Archived » Test and Performance Tools Platform (TPTP) » Integrated agent controller does not work: launching eclipse hangs
Integrated agent controller does not work: launching eclipse hangs [message #123454] Wed, 20 February 2008 00:47
Originally posted by: swati_gkd.rediffmail.com
I am using tptp-4.4 with eclipse 3.3.0 on windows.
When tptp is linked with eclipse using linking mechanism, running
tests hangs at "preparing and deploying" at "31%" on localhost. Here
Integrated agent controller is started in the background and connection is
also successful.
If a standalone agent controller is started then eclipse launch and
execution of tests works (with linked tptp). For the localhost, IAC should
work.
If eclipse is updated for tptp(all tptp plugins copied into eclipse
installation) then IAC works perfectly.
This seems to be a problem with the tptp with linking mechanism + IAC.
With the linking mechanism the tests can be run in quick mode and not
in standard mode.
Please let me know, if this is know.
Thanks and Regards,
Swati
Previous Topic:TPTP Profiler GUI component re-use
Next Topic:Error Profiling wasce
Current Time: Sun Nov 02 13:26:39 EST 2025
Powered by FUDForum. Page generated in 0.53931 seconds
