Home » Newcomers » Newcomers » Is there a way to control the size of the applet?
Is there a way to control the size of the applet? [message #123449] Sun, 11 December 2005 15:41 Go to next message
Originally posted by: khvatov.yahoo.com
Hi, all.
I could not find a way to control the size of the applet when I run it
in Eclipse.
Is there a way to specify the size of an applet when you run it?
Please help.
Thank you.
Alex
Re: Is there a way to control the size of the applet? [message #123590 is a reply to message #123449] Mon, 12 December 2005 09:05 Go to previous messageGo to next message
Alex,
Bring up the launch configuration for your Applet (from the menu select
Run... instead of Run). On the parameters tab of the run configuration
there are fields to specify the height and width of the applet.
Hope this helps,
- Jeff
Re: Is there a way to control the size of the applet? [message #124049 is a reply to message #123590] Wed, 14 December 2005 09:27 Go to previous message
Thanks, it did.
Alex
Jeff Myers wrote:
> Alex,
> Hope this helps,
> - Jeff
Previous Topic:Consol not available
Next Topic:convert MSVC 6.0 workspaces/projects to eclipse
Current Time: Tue Jul 22 19:50:23 EDT 2025
Powered by FUDForum. Page generated in 0.28627 seconds
