Home » Archived » BIRT » Printer icon missing from Viewer in 2.0 Released
Printer icon missing from Viewer in 2.0 Released [message #123429] Thu, 02 February 2006 16:01 Go to next message
Originally posted by: nadeemabbasi1.yahoo.com
When i open up a report design using the viewer running under JBoss, the
frameset set only has 3 buttons (TOC/Export/Run). The PRINTER button is
missing. Anyone has any ideas what the problem could be?
Re: Printer icon missing from Viewer in 2.0 Released [message #123479 is a reply to message #123429] Thu, 02 February 2006 17:25 Go to previous message
The Print button was removed in the final 2.0 release build to address bug
123854.
There are other threads about this issue. See "No longer able to use PDF
mode in the BIRT viewer since 2.0 final" dated 1/25/2006.
You can still generate a PDF report via the URL, and by selecting Preview as
PDF in the report designer.
"Nadeem" <nadeemabbasi1@yahoo.com> wrote in message
news:8b7a6a4949672a94a9ad4600934296f6$1@www.eclipse.org...
Previous Topic:Pie Chart to access data from multiple dataset (Urgent)
Next Topic:Page N of M
Current Time: Sat Nov 08 21:32:10 EST 2025
Powered by FUDForum. Page generated in 0.02593 seconds
