Home » Eclipse Projects » GEF » Bug check + RCP key handler
Bug check + RCP key handler [message #123359] Sun, 21 March 2004 11:23 Go to next message
I'm using the latest integration release of GEF. When I launch my
application independent of the org.eclipse.ide, the keyhandler seems to
work okay (i.e. CTRL + Z) generates an undo event. However, when my
application is launched using an RCP configuration key events are ignored.
Is this a bug? Is there a a fix independent of introducing
org.eclipse.ide?
Thanks.
James
Re: Bug check + RCP key handler [message #123372 is a reply to message #123359] Sun, 21 March 2004 11:37 Go to previous messageGo to next message
I should have said here "When I launch my application using
org.eclipse.ide".
> org.eclipse.ide?
> Thanks.
> James
Re: Bug check + RCP key handler [message #123397 is a reply to message #123372] Sun, 21 March 2004 17:49 Go to previous messageGo to next message
The IDE declares a global UNDO action. Without this action, registering an
action handler will not do anything.
You need to put an Undo action on the Menubar yourself in RCP.
"James Willans" <jwillans@cs.york.ac.uk> wrote in message
news:c3kgbl$909$1@eclipse.org...
> org.eclipse.ide".
ignored.
> > org.eclipse.ide?
> > Thanks.
> > James
Re: Bug check + RCP key handler [message #123421 is a reply to message #123397] Sun, 21 March 2004 18:16 Go to previous messageGo to next message
I already do this, I have added undo (and redo) to the menubar and the
coolbar in my RCP app, but I am unable to trigger it using CTRL+Z,
although this works fine when I include org.eclipse.ide.
Re: Bug check + RCP key handler [message #124504 is a reply to message #123421] Fri, 26 March 2004 10:27 Go to previous message
And is there anywhere where you wrote the string "CTRL+Z"??
You need to use a keybinding to declare the command and its accelerator.
Then do what you are doing and make sure the aciton has the command's ID
set. Actions and Commands are a PITA, so go ask the experts on
eclipse.platform if you can't get it to work.
news:c3l7p2$vcp$1@eclipse.org...
an
Previous Topic:Absolute Position
Next Topic:CutRetargetAction missing
Current Time: Tue Jul 22 19:50:05 EDT 2025
Powered by FUDForum. Page generated in 0.05307 seconds
