Rendering of TreeViewer on SashForm [message #123077] |
Thu, 26 February 2009 02:24  |
Originally posted by: bjoern.bjoernfischer.de
--------------070807060101000801020501
Hello everybody,
I have a SashForm with a TreeViewer on one side of the Sash. The
TreeViewer has SWT.BORDER set (see end of the post for a code snippet).
It seems that RAP renders the TreeViewer a little bit wider than it is
intendet, and therefore the TreeViewer's scroollbars are partly overlaid
by the Sash in both directions (vertically and horizontally).
The screenshot tv_on_sash.png shows how it should be rendered (and is
rendered with SWT), tv_on_sash_rap.png shows the (slightly wrong)
rendering by RWT.
This is not a critical problem since it can be solved by turning off
SWT.BORDER on the TreeViewer, but it is at least distracting for
single-sourcers. Also I could not reproduce this with an different
control than a TreeViewer (e.g. the text widget on the left side is
shown correctly, I also tried a TableViewer which does not show this
behaviour). My Target is 1.2 M5.
Bj
Re: Rendering of TreeViewer on SashForm [message #123143 is a reply to message #123077] |
Thu, 26 February 2009 05:11   |
Hi Björn,
your snippet renders fine here. Which version do you use? Any custom themes?
Ralf
Björn Fischer wrote:
> Hello everybody,
> rendering by RWT.
> Björn
> P.S.: Here is the Snippet (move the contents of createUI to the
> constructor in order to run it standalone as Java app):
> import org.eclipse.jface.viewers.TreeViewer;
> import org.eclipse.rwt.lifecycle.IEntryPoint;
> import org.eclipse.swt.SWT;
> import org.eclipse.swt.custom.SashForm;
> import org.eclipse.swt.layout.FillLayout;
> import org.eclipse.swt.widgets.Display;
> import org.eclipse.swt.widgets.Shell;
> import org.eclipse.swt.widgets.Text;
> public class SashFormExample implements IEntryPoint {
> Display display = new Display();
> Shell shell = new Shell(display);
> SashForm sashForm;
> SashForm sashForm2;
> public SashFormExample() {
> public static void main(String[] args) {
> new SashFormExample();
> @Override
> public int createUI() {
> shell.setLayout(new FillLayout());
> sashForm = new SashForm(shell, SWT.HORIZONTAL);
> TreeViewer text1 = new TreeViewer(sashForm, SWT.BORDER);
> text1.getTree().setItemCount(25);
> Text text2 = new Text(sashForm,
> SWT.CENTER|SWT.BORDER|SWT.MULTI|SWT.V_SCROLL);
> text2.setText("Text in pane #2\n" +
> "Text in pane #2\n" );
> sashForm.setWeights(new int[]{1, 2});
> shell.setSize(450, 200);
> shell.open();
> //textUser.forceFocus();
> // Set up the event loop.
> while (!shell.isDisposed()) {
> if (!display.readAndDispatch()) {
> // If no more entries in event queue
> display.sleep();
> display.dispose();
> return 0;
Re: Rendering of TreeViewer on SashForm [message #123861 is a reply to message #123227] |
Fri, 06 March 2009 08:45  |
Ralf Sternberg schrieb:
>> I am using RAP Version 1.2.0-M5-20090210-1243. No custom Themes. What
>> else could I check?
> Could you check with latest CVS? As we cannot reproduce the problem here
> chances are that this has been fixed by a change in the SashFolder past M5.
> Regards, Ralf
Hi Ralf,
I checked against current CVS version and this issue seems to be fixed.
Thanks for your advice!
Björn
FUDForum. Page generated in 0.04078 seconds
