Home » Language IDEs » ServerTools (WTP) » how to change the Java Output folder in wtp(it seems it doesn't work)
how to change the Java Output folder in wtp(it seems it doesn't work) [message #122982] Tue, 19 July 2005 10:39 Go to next message
Originally posted by: eagleinfly.gmail.com
in project properties diaglog, =>select Java Build Path =>Source=> set
"Allow output folder" checkbox checked,
change the ouput folder to /myproject/WebContent
save
later, it changes to .deployables/myproject/WEB-INF/classes automatically.
sometimes it doesn't matter,
but sometimes, the project cann't be build, it sais some class cann't be
found, and after i change the output folder to myproject/WebContent, the
project has built successed, but the output folder still changed to
..deployables/myproject/WEB-INF/classes automatically.
i don't know why,
is there anyone can help?
thanks
Re: how to change the Java Output folder in wtp(it seems it doesn't work) [message #123247 is a reply to message #122982] Tue, 19 July 2005 23:46 Go to previous message
> save
> i don't know why,
> thanks
Currently the .deployables is the default output folder and cannot be
changed. This will change post 0.7 release of wtp where the .deployables
will be removed and all runtime code will generated at publish time to
the server. I am not sure why you are seeing the problem saying "some
class cann't be found". If you have reproduceable scenario for the
problem please file a wtp bug report for this problem.
Previous Topic:How to Convert a Java Project to a Web Project
Next Topic:JBoss 4.0.2 with M5
Current Time: Mon Oct 20 10:30:02 EDT 2025
Powered by FUDForum. Page generated in 0.25509 seconds
