Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Hiberante and Hbxml resource
| [Teneo] Hiberante and Hbxml resource [message #122894] |
Thu, 22 May 2008 15:21  |
Hello!
My application uses a GMF based editor with Teneo to store the model
instances to the database. Currently i am using two resources, the HBXML
resource for the editor and the hibernate resource for my other model
entities.
Attributes of the GMF related model entities have non-containment
references to model entities in the hibernate resource. When opening my
diagram editor I load the hibernate resource, but when I create a new
model instance and save it, then I also have to reopen my GMF diagram
editor to be able to reference it.
So my question is: Would it be a disadvantage if I use the HBXML resource
for all of my model entities?!? Would it work?! Would there be any
limitiations?!
If yes, then how can I manage my problem?!?
Matthias
| Re: [Teneo] Hiberante and Hbxml resource [message #122898 is a reply to message #122894] |
Thu, 22 May 2008 18:05   |
Hi Matthias,
The HibernateXMLResource inherits from the HibernateResource and only adds minimal xml specifics. So
afaics you can use the HibernateXMLResource for all your data.
gr. Martin
Matthias wrote:
> Hello!
> entities.
> resource for all of my model entities?!? Would it work?! Would there be
> any limitiations?!
> Best regards,
> Matthias
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Hiberante and Hbxml resource [message #122967 is a reply to message #122965] |
Mon, 26 May 2008 08:31  |
Hi Matthias,
See comments inline.
gr. Martin
Matthias wrote:
> Hello Martin,
> thank you for your answer.
> I have some additional questions (honestly I do not know Hibernate very
> well so these questions might also be related to Hibernate in general).
> 1. My persisted model instances have ids like 987845 and 345152 so on.
> Why does not counting start at 1 even on an empty database?!?
MT>> It should start with 1, you can check the database configuration, you can also try to remove
the database and start from fresh again. Are you sure that your id's are autosequence id's?
> 2. I have a plugin that registers a "persistence" service, that provides
> storage to databases with Teneo. The service provides the interface
> method "getResource" that returns in fact the HibernateXMLResource. This
> resources gets loaded on startup of the plug-in and unloaded at the end
> of the plug-in lifecycle. Is this good practice (because in the GMF
> tutorial you load and un-load a new resource when you need it.). Saving
> the resource also does a commit, right?!
MT>> Yes save does a commit, the resource only opens a transaction during the load/save. So in
between it does not put load on the database. So this is good practice.
> 3. In terms of performance and best practice: I want to search a model
> object with a specific name in my database. What do you think, iterating
> the resource and making instanceofs and equals calls or creating a HSQL
> on the session object?!?
MT>> It all depends on your database size. I prefer querying because it always works (also with
larger databases).
> 4. I have a GMF based model instance editor and I am using Teneo for
> diagram and model persistence. My meta-model defines for instance that
> the model object "Company" must have a (ONE) name. When I create a
> Company in the diagram editor and do not set a name, I get an error
> message. Is there any mechanism to provide a self defined error message
> (because the default one might be to technical and implementation
> specific for the end user).
MT>> I would have expected that EMF validation would have caught this one upfront. Can you check if
validation is done before/during save? (see the StoreResource.validateContents method).
> Thank you for any response...
> Best regards,
> Matthias
The Netherlands
| Re: [Teneo] Hiberante and Hbxml resource [message #618149 is a reply to message #122894] |
Hi Matthias,
gr. Martin
Matthias wrote:
> Hello!
> entities.
> any limitiations?!
> Best regards,
> Matthias
The Netherlands
| Re: [Teneo] Hiberante and Hbxml resource [message #618966 is a reply to message #122898] |
Mon, 26 May 2008 03:34  |
Hello Martin,
1. My persisted model instances have ids like 987845 and 345152 so on. Why
storage to databases with Teneo. The service provides the interface method
resources gets loaded on startup of the plug-in and unloaded at the end of
the plug-in lifecycle. Is this good practice (because in the GMF tutorial
you load and un-load a new resource when you need it.). Saving the
the resource and making instanceofs and equals calls or creating a HSQL on
diagram and model persistence. My meta-model defines for instance that the
model object "Company" must have a (ONE) name. When I create a Company in
the diagram editor and do not set a name, I get an error message. Is there
any mechanism to provide a self defined error message (because the default
one might be to technical and implementation specific for the end user).
Matthias
| Re: [Teneo] Hiberante and Hbxml resource [message #618968 is a reply to message #122965] |
Hi Matthias,
gr. Martin
Matthias wrote:
> Hello Martin,
larger databases).
> Best regards,
> Matthias
The Netherlands
Current Time: Thu Nov 06 07:57:26 EST 2025
Powered by FUDForum. Page generated in 0.04837 seconds
