Home » Eclipse Projects » Eclipse Platform » ant failure after 1.5.4 upgrade
ant failure after 1.5.4 upgrade [message #122891] Thu, 04 September 2003 20:53 Go to next message
Originally posted by: paul.moore06.ca.com
To get javah working I upgraded my ant to 1.5.4. Eclipse will not run ant
any more now after changing the runtime jar files in Windows->Pref->Ant
!ENTRY org.eclipse.ant.core 4 1 Sep 04, 2003 17:49:35.481
!MESSAGE (class: org/apache/xerces/parsers/IntegratedParserConfiguration,
method: configurePipeline signature: ()V) Incompatible type for getting or
setting field
!STACK 0
java.lang.VerifyError: (class:
org/apache/xerces/parsers/IntegratedParserConfiguration, method:
configurePipeline signature: ()V) Incompatible type for getting or setting
field
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
org.apache.xerces.util.ObjectFactory.newInstance(ObjectFacto ry.java:247)
org.apache.xerces.util.ObjectFactory.findJarServiceProvider( ObjectFactory.java:380)
org.apache.xerces.util.ObjectFactory.createObject(ObjectFact ory.java:191)
org.apache.xerces.util.ObjectFactory.createObject(ObjectFact ory.java:123)
at org.apache.xerces.parsers.SAXParser.<init>(SAXParser.java:95)
at org.apache.xerces.jaxp.SAXParserImpl.<init>(SAXParserImpl.java:101)
org.apache.xerces.jaxp.SAXParserFactoryImpl.newSAXParser(SAX ParserFactoryImpl.java:95)
at org.apache.tools.ant.util.JAXPUtils.newSAXParser(JAXPUtils.j ava:188)
at org.apache.tools.ant.util.JAXPUtils.getParser(JAXPUtils.java :137)
org.apache.tools.ant.helper.ProjectHelperImpl.parse(ProjectH elperImpl.java:134)
org.apache.tools.ant.ProjectHelper.configureProject(ProjectH elper.java:117)
org.eclipse.ant.internal.core.ant.InternalAntRunner.parseBui ldFile(InternalAntRunner.java:289)
org.eclipse.ant.internal.core.ant.InternalAntRunner.getTarge ts(InternalAntRunner.java:314)
at org.eclipse.ant.core.AntRunner.getAvailableTargets(AntRunner .java:216)
org.eclipse.ui.externaltools.internal.ant.model.AntUtil.getT argets(AntUtil.java:173)
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntTargetsTab.getTargets(AntTargetsTab.java:240)
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntTargetsTab.initializeFrom(AntTargetsTab.java:306)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.handleTabSelected(LaunchConfigurati onTabGroupViewer.java:974)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setActiveTab(LaunchConfigurationTab GroupViewer.java:1073)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.setActiveTab(LaunchConfigurationsDialog.ja va:1844)
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.RunAntStatusHandler.handleStatus(RunAntStatusHandler.java :30)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleStatus(LaunchConfigurationsDialog.ja va:1875)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationDialog.initializeContent(LaunchConfigurationDialog .java:76)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.createContents(LaunchConfigurationsDialog. java:337)
at org.eclipse.jface.window.Window.create(Window.java:302)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.create(LaunchConfigurationsDialog.java:182 6)
at org.eclipse.jface.window.Window.open(Window.java:552)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:460)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationPropertiesDialog.open(LaunchConfigurationPropertie sDialog.java:256)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia log(DebugUITools.java:424)
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchShortcut.launch(AntLaunchShortcut.java:145)
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntLaunchShortcut.launch(AntLaunchShortcut.java:108)
org.eclipse.ui.externaltools.internal.ant.launchConfiguratio ns.AntRunActionDelegate.run(AntRunActionDelegate.java:37)
org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDel egate.java:71)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:241)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1838)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1545)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:858)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
Re: ant failure after 1.5.4 upgrade [message #122896 is a reply to message #122891] Thu, 04 September 2003 21:19 Go to previous message
See the readme bug report
https://bugs.eclipse.org/bugs/show_bug.cgi?id=34151
Note that the latest 3.0 builds come with Ant 1.5.4
Darins
"Paul Moore" <paul.moore06@ca.com> wrote in message
news:bj8mqj$bd4$1@eclipse.org...
> setting field
> !STACK 0
> field
> at
> at
va:380)
> at
> at
> at
l.java:95)
> at
34)
> at
> at
ntRunner.java:289)
> at
nner.java:314)
> at
ava:173)
> at
..getTargets(AntTargetsTab.java:240)
> at
..initializeFrom(AntTargetsTab.java:306)
> at
upViewer.handleTabSelected(LaunchConfigurationTabGroupViewer .java:974)
> at
upViewer.setActiveTab(LaunchConfigurationTabGroupViewer.java :1073)
> at
g.setActiveTab(LaunchConfigurationsDialog.java:1844)
> at
andler.handleStatus(RunAntStatusHandler.java:30)
> at
g.handleStatus(LaunchConfigurationsDialog.java:1875)
> at
..initializeContent(LaunchConfigurationDialog.java:76)
> at
g.createContents(LaunchConfigurationsDialog.java:337)
> at
g.create(LaunchConfigurationsDialog.java:1826)
> at
> at
tiesDialog.open(LaunchConfigurationPropertiesDialog.java:256 )
> at
..java:424)
> at
> at
> at
> at
> at
> at
> at
> at
tem.java:397)
> at
> at
a:858)
Previous Topic:Problems with v4all_2.1.0
Next Topic:eclipse install directory
Current Time: Fri Nov 21 04:42:31 EST 2025
Powered by FUDForum. Page generated in 0.03239 seconds
