| Calling site build from ant script [message #122871] |
Thu, 04 September 2003 19:01  |
Originally posted by: matt_conway.nospam.i2.com
Is there anyway to build an update site project from an ant script?
Ideally, I'd like to be able to just run an ant script in an UpdateSite
project and have it build all the features and plugins it has
conifigured, and then push them and the site.xml to a website.
The only thing I see that might be of use is the eclipse.buildScript
task for generating an ant script for features/plugins, but there
doesn't seem to be an equivalent for site.xml - I could parse
site.xml/sitebuild.xml and do the right thing, but since this is already
automated in the UI, shouldn't there also be a way to do it via an ant task?
Matt
| Re: Calling site build from ant script [message #180666 is a reply to message #123099] |
Thu, 15 January 2004 17:04   |
Originally posted by: john.ellis.ascentialsoftware.com
Matt,
Did you ever find out how to automate an update site build using ant or any
other means?
- John
"Matt Conway" <matt_conway@nospam.i2.com> wrote in message
news:bja85i$kpb$1@eclipse.org...
> I already have an Update Site project - what I want to do is add an ant
> build script to it which will call the build step that I normally call
> from the site.xml editor UI. This way I can automate the distribution
> of my features - i.e. update cvs, label, build, distribute all
> automatically instead of me having to clickity click click =)
> Matt
> Chris Laffra wrote:
> > You could use the PDE wizard to create a Update Site Project for you?
> > Very simple to use.
> > Chris
> > news:bj8g76$6hl$1@eclipse.org...
| Re: Calling site build from ant script [message #183769 is a reply to message #180666] |
Thu, 22 January 2004 17:48  |
Nope - I started doing something by hand - basically calling the right
targets in the generated buildfile (which would still have to be
generated manually from the ui), but ran into some bugs (I think) in PDE
which prevented me from doing what I needed.
Matt
John Ellis wrote:
> Matt,
> other means?
FUDForum. Page generated in 0.03857 seconds
