Home » Archived » BIRT » Missing Data Sources
Missing Data Sources [message #122853] Wed, 01 February 2006 14:40 Go to next message
I just installed BIRT 2.0 and discovered after the install that the only
data source available when I create a new data source is "Scripted Data
Source." Where is "Classic Models Inc.", JDBC etc. ?
Re: Missing Data Sources [message #122916 is a reply to message #122853] Wed, 01 February 2006 18:14 Go to previous messageGo to next message
Hi Mark,
I had a similar problem but I discovered I hadn't installed correctly. I
reinstalled and then started Eclipse with the -clean option.
Also, just confirm that you do have the two default drivers in the right
eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_2.0.0:
derby.jar
oda-jdbc.jar
Good luck.
"Mark Ericson" <mark@mindreef.com> wrote in message
news:drr2rm$eht$1@utils.eclipse.org...
Re: Missing Data Sources [message #122968 is a reply to message #122916] Thu, 02 February 2006 05:54 Go to previous messageGo to next message
Interesting, I simply restarted Eclipse and data sources appeared!
"Paul Reeves" <preeves@actuate.com> wrote in message
news:drrf96$ckq$1@utils.eclipse.org...
> Hi Mark,
> location:
> derby.jar
> oda-jdbc.jar
> Good luck.
Re: Missing Data Sources [message #123286 is a reply to message #122968] Thu, 02 February 2006 14:22 Go to previous message
Mark,
That's good to hear. Eclipse caches information/resources that plugins use,
which can be quite helpful. It is also a pain when you forget that you have
to restart Eclipse with the -clean option when you add new drivers.
news:drsodt$p1h$1@utils.eclipse.org...
>> Hi Mark,
>> location:
>> derby.jar
>> oda-jdbc.jar
>> Good luck.
Previous Topic:How to add a Page Breaks in a Report?
Next Topic:Chart sizing
Current Time: Tue Nov 11 22:43:52 EST 2025
Powered by FUDForum. Page generated in 0.03687 seconds
