java.lang.VerifyError [message #122737] |
Thu, 04 September 2003 11:38  |
Originally posted by: karikday.yahoo.com
While updating my project from a CVS repository I get the following
exception and stack trace. I'm running Eclipse 2.1.0 on W2K SP2. I've
been running this installation on my machine for nearly a month now
without any problems. I am not trying to run any of my own code, just
perform a CVS update. Any pointers would be appreciated.
!ENTRY org.eclipse.ui 4 4 Sep 04, 2003 11:20:02.252
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Sep 04, 2003 11:20:02.252
!MESSAGE (class: com/objectlearn/jdt/j2ee/ui/actions/AddNewEJBAction,
method: run signature: (Lorg/eclipse/jface/action/IAction;)V) Incompatible
object argument for function call
!STACK 0
java.lang.VerifyError: (class:
com/objectlearn/jdt/j2ee/ui/actions/AddNewEJBAction, method: run
signature: (Lorg/eclipse/jface/action/IAction;)V) Incompatible object
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:15 90)
at java.lang.Class.getConstructor0(Class.java:1762)
at java.lang.Class.newInstance0(Class.java:276)
at java.lang.Class.newInstance(Class.java:259)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:138)
org.eclipse.core.internal.plugins.PluginDescriptor.createExe cutableExtension(PluginDescriptor.java:167)
org.eclipse.core.internal.plugins.ConfigurationElement.creat eExecutableExtension(ConfigurationElement.java:103)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:151)
org.eclipse.ui.internal.PluginAction.createDelegate(PluginAc tion.java:103)
org.eclipse.ui.internal.PluginAction.selectionChanged(Plugin Action.java:270)
at org.eclipse.ui.internal.PluginAction.<init>(PluginAction.java:94)
org.eclipse.ui.internal.ObjectPluginAction.<init>(ObjectPluginAction.java:36)
org.eclipse.ui.internal.ActionDescriptor.createAction(Action Descriptor.java:201)
org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:126)
org.eclipse.ui.internal.ActionDescriptor.<init>(ActionDescriptor.java:67)
org.eclipse.ui.internal.ObjectActionContributor.createAction Descriptor(ObjectActionContributor.java:133)
org.eclipse.ui.internal.PluginActionBuilder.readElement(Plug inActionBuilder.java:144)
org.eclipse.ui.internal.ObjectActionContributor.readElement( ObjectActionContributor.java:185)
org.eclipse.ui.internal.registry.RegistryReader.readElements (RegistryReader.java:136)
org.eclipse.ui.internal.registry.RegistryReader.readElementC hildren(RegistryReader.java:126)
org.eclipse.ui.internal.ObjectActionContributor.readConfigEl ement(ObjectActionContributor.java:163)
org.eclipse.ui.internal.ObjectActionContributor.isApplicable To(ObjectActionContributor.java:149)
org.eclipse.ui.internal.ObjectContributorManager.isApplicabl eTo(ObjectContributorManager.java:235)
org.eclipse.ui.internal.ObjectActionContributorManager.contr ibuteObjectActions(ObjectActionContributorManager.java:123)
org.eclipse.ui.internal.PopupMenuExtender.addObjectActions(P opupMenuExtender.java:57)
org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(Po pupMenuExtender.java:78)
org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuMan ager.java:255)
org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuM anager.java:334)
at org.eclipse.jface.action.MenuManager.access$0(MenuManager.ja va:331)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager .java:343)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:116)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :81)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:840)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:865)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:845)
at org.eclipse.swt.widgets.Control.WM_INITMENUPOPUP(Control.jav a:3141)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:2785 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1229)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:2361 )
at org.eclipse.swt.internal.win32.OS.TrackPopupMenu(Native Method)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:218)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:1863)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1538)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1402)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1385)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:291)
at org.eclipse.core.launcher.Main.run(Main.java:747)
at org.eclipse.core.launcher.Main.main(Main.java:583)
!ENTRY org.eclipse.ui 4 4 Sep 04, 2003 11:27:11.28
!ENTRY org.eclipse.ui 4 0 Sep 04, 2003 11:27:11.28
!MESSAGE jzentry == 0,
jzfile = 185457888,
total = 87,
name = C:\dev\eclipse\workspace\wholesale\WEB-INF\lib\tds.jar,
i = 69,
message = invalid LOC header (bad signature)
!STACK 0
java.lang.InternalError: jzentry == 0,
jzfile = 185457888,
total = 87,
i = 69,
at java.util.zip.ZipFile$2.nextElement(ZipFile.java:321)
org.eclipse.jdt.internal.core.builder.ClasspathJar.isPackage (ClasspathJar.java:96)
org.eclipse.jdt.internal.core.builder.ClasspathJar.findClass (ClasspathJar.java:69)
org.eclipse.jdt.internal.core.builder.NameEnvironment.findCl ass(NameEnvironment.java:283)
org.eclipse.jdt.internal.core.builder.NameEnvironment.findTy pe(NameEnvironment.java:299)
org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.c reatePackage(LookupEnvironment.java:332)
org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScop e.buildTypeBindings(CompilationUnitScope.java:83)
org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.b uildTypeBindings(LookupEnvironment.java:119)
org.eclipse.jdt.internal.compiler.Compiler.beginToCompile(Co mpiler.java:301)
at org.eclipse.jdt.internal.compiler.Compiler.compile(Compiler. java:324)
org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.c ompile(AbstractImageBuilder.java:195)
org.eclipse.jdt.internal.core.builder.AbstractImageBuilder.c ompile(AbstractImageBuilder.java:168)
org.eclipse.jdt.internal.core.builder.BatchImageBuilder.buil d(BatchImageBuilder.java:51)
org.eclipse.jdt.internal.core.builder.JavaBuilder.buildAll(J avaBuilder.java:194)
org.eclipse.jdt.internal.core.builder.JavaBuilder.build(Java Builder.java:122)
org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:427)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:889)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:125)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:181)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:191)
org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:151)
org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:165)
org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:243)
org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:212)
org.eclipse.core.internal.resources.Workspace.endOperation(W orkspace.java:884)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1600)
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:85)
org.eclipse.team.internal.ccvs.ui.repo.RepositoryManager.run (RepositoryManager.java:796)
org.eclipse.team.internal.ccvs.ui.actions.CVSAction$1.run(CV SAction.java:242)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:101)
KD
Re: java.lang.VerifyError [message #122793 is a reply to message #122737] |
Thu, 04 September 2003 16:37   |
Did you install a new JDK? Perhaps this one is more picky?
When you do Project > Rebuild All, do you get the same problem?
Chris
"Kari Day" <karikday@yahoo.com> wrote in message
news:bj7m9m$bi4$1@eclipse.org...
> !STACK 0
> at
> at
> at
> at
:151)
> at
> at
> at
> at
201)
> at
> at
> at
> at
java:144)
> at
ributor.java:185)
> at
java:136)
> at
Reader.java:126)
> at
> at
> at
> at
> at
..java:57)
> at
java:78)
> at
> at
> at
> at
a:845)
> at
> at
..java:25)
> jzfile = 185457888,
> total = 87,
> i = 69,
> !STACK 0
> jzfile = 185457888,
> total = 87,
> i = 69,
> at
va:96)
> at
va:69)
> at
ent.java:283)
> at
nt.java:299)
> at
> at
> at
> at
> at
> at
> at
der.java:51)
> at
194)
> at
> at
> at
:889)
> at
25)
> at
81)
> at
91)
> at
> at
:889)
> at
65)
> at
va:243)
> at
> at
4)
> at
..java:85)
> at
er.java:796)
> at
> at
..java:101)
> KD
Re: java.lang.VerifyError [message #122820 is a reply to message #122737] |
Thu, 04 September 2003 17:10  |
Originally posted by: olivier_thomann.ca.ibm.comNOSPAM
Le Thu, 4 Sep 2003 15:38:30 +0000 (UTC), karikday@yahoo.com (Kari Day)
>!STACK 0
You have a wrong version of Xerces on the classpath.
Olivier
FUDForum. Page generated in 0.26068 seconds
