Unable to create Java project [message #11206] |
Fri, 21 January 2005 08:41  |
Originally posted by: info.funkalot.nl
after installing Eclipse (3.0.1 win32) I tried to create a java project,
but there is no option to do it, only the cvs and the simple folders are
shown in /file/new/project. When i look in the configuration settings I
see that eclipse sees my java install (j2sdk1.5.0). What did i do wrong?
Re: Unable to create Java project [message #11419 is a reply to message #11272] |
Fri, 21 January 2005 11:00  |
I downloaded the java eclipse-platform-SDK-3.0.1-win32.zip, I thaught that
was enough. I will check it out. thanks.
Evert-Jan Stoel
"Jeff Myers" <myersj@nospam.gmail.com> schreef in bericht
news:csr458$hit$1@www.eclipse.org...
> Are you sure you downloaded the eclipse-SDK zip and not just the
> platform runtime? If you did download the platform runtime, you can add
> the Java development plug-ins by downloading and installing the JDT
> Runtime binary. But it's likely to be easier for future development to
> start over with the eclipse-SDK.
> - Jeff
> Evert-Jan Stoel wrote:
> > Hello,
FUDForum. Page generated in 0.09910 seconds
