Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » org.eclipse.emf.teneo.hibernate has vanished from update site ?
org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122344] Tue, 13 May 2008 10:51 Go to next message
Hi everyone,
Does anyone know why org.eclipse.emf.teneo.hibernate has vanished from
interim update site ?
http://download.eclipse.org/modeling/emft/updates/interim/si te.xml
There's Teneo but no more teneo.hibernate ...
Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122355 is a reply to message #122344] Tue, 13 May 2008 10:59 Go to previous messageGo to next message
I'd like to add that I used to use this update site :
http://download.eclipse.org/modeling/emft/updates/site-inter im.xml
according to installation procedure
http://www.elver.org/hibernate/installation.html
But this address is unavailable so I searched a bit and found this one as
a replacement
http://download.eclipse.org/modeling/emft/updates/interim/si te.xml but
this update site contains no org.eclipse.emf.teneo.hibernate feature.
Guillaume CHATELET wrote:
> Hi everyone,
> Cheers,
> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122364 is a reply to message #122355] Tue, 13 May 2008 11:17 Go to previous messageGo to next message
Hi Guillaume,
The hibernate and jpox part are distributed together within the Teneo feature(s). So if you install
the Teneo sdk or runtime you should get it.
Thanks for letting me know about the wrong link. I'll change that.
gr. Martin
> as a replacement
>> Hi everyone,
>> Cheers,
>> Guillaume
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122441 is a reply to message #122364] Wed, 14 May 2008 02:54 Go to previous messageGo to next message
Hi Martin,
Thx for the quick answer.
I'm using buckminster to materialize teneo feature and the resolve phase leads to a missing file. Here is the error :
Unable to retrieve remote reference " http://download.eclipse.org/modeling/emft/updates/interim/fe atures/org.eclipse.uml2.examples_2.2.0.v200803260935.jar".
Server returned HTTP response code: "404 Not Found" for URL: http://download.eclipse.org/modeling/emft/updates/interim/fe atures/org.eclipse.uml2.examples_2.2.0.v200803260935.jar.
It seems, either the site.xml contains an error or the file really is missing. Can you check it ?
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> feature(s). So if you install the Teneo sdk or runtime you should get it.
> gr. Martin
>> as a replacement
>>> Hi everyone,
>>> from interim update site ?
>>> Cheers,
>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122451 is a reply to message #122441] Wed, 14 May 2008 03:05 Go to previous messageGo to next message
Just let me add that Buckminster finds the dependencies by parsing the plugin.xml of each features/plugin. So org.eclipse.uml2.examples might be a dependency of org.eclipse.emf.teneo . Does it make sense ?
user@domain.invalid wrote:
> Hi Martin,
> Cheers,
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>> one as a replacement
>>> but this update site contains no org.eclipse.emf.teneo.hibernate
>>> feature.
>>>> Hi everyone,
>>>> Cheers,
>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122481 is a reply to message #122451] Wed, 14 May 2008 06:43 Go to previous messageGo to next message
Hi Guillaume,
Teneo has no dependency on uml2. Can you check if you not accidently also download/install another
feature which uses uml2?
gr. Martin
>> Hi Martin,
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> it.
>>> gr. Martin
>>>> feature.
>>>>> Hi everyone,
>>>>> Cheers,
>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122538 is a reply to message #122481] Fri, 16 May 2008 08:14 Go to previous messageGo to next message
Hi Martin,
I checked it with Thomas Hallgren from Buckminster project :
http://www.eclipse.org/newsportal/article.php?id=132&gro up=eclipse.tools.buckminster#132
The problem is there's an inconsistency in the EMFT site.xml -> http://download.eclipse.org/modeling/emft/updates/interim/si te.xml
Thomas Hallgren wrote:
> You can report that the following features referenced from the site.xml includes the missing uml2.examples feature.
> org.eclipse.emf.search.all.sdk_0.7.0.HEAD.jar
> org.eclipse.emf.search.all.sdk_0.7.0.v200805020316.jar
> org.eclipse.emf.search.all.sdk_0.7.0.v200805031222.jar
Can you fix this ?
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> also download/install another feature which uses uml2?
> gr. Martin
>>> Hi Martin,
>>> Cheers,
>>> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> Teneo feature(s). So if you install the Teneo sdk or runtime you
>>>> should get it.
>>>> gr. Martin
>>>>> feature.
>>>>>> Hi everyone,
>>>>>> Cheers,
>>>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122562 is a reply to message #122538] Fri, 16 May 2008 10:08 Go to previous messageGo to next message
Hi Guillaume,
I am not sure, is this really a Teneo issue? I am not yet convinced about that.
Maybe it is an issue of another EMFT component... (maybe search?)
gr. Martin
> Hi Martin,
> Can you fix this ?
> Cheers,
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>>> Hi Martin,
>>>> Cheers,
>>>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> should get it.
>>>>> gr. Martin
>>>>>> feature.
>>>>>>> Hi everyone,
>>>>>>> Cheers,
>>>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #122588 is a reply to message #122562] Fri, 16 May 2008 11:25 Go to previous message
Originally posted by: codeslave.ca.ibm.com
Surprisingly enough, emf.search == EMF Search [0].
(I know, what's up with the logical mapping between feature namespace
and component name?) :)
If EMF Search depends on UML2, just add one of the MDT update sites as
well in order to resolve those dependencies. Choices are listed here [1].
Or, simpler, install from the Ganymede site, since it includes
everything in one site [2]. Or use the bleeding edge staging site [3].
[0] http://www.eclipse.org/modeling/emft/?project=search#search
[1] http://www.eclipse.org/modeling/mdt/updates/
[2] http://download.eclipse.org/releases/ganymede/
[3] http://download.eclipse.org/releases/ganymede/staging/
Nick
Martin Taal wrote:
> Hi Guillaume,
> about that.
> gr. Martin
>> Hi Martin,
>> Can you fix this ?
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Martin
>>>>> Hi Martin,
>>>>> Cheers,
>>>>> Guillaume
>>>>> Martin Taal wrote:
>>>>>> Hi Guillaume,
>>>>>> should get it.
>>>>>> gr. Martin
>>>>>>> this one as a replacement
>>>>>>> feature.
>>>>>>>> Hi everyone,
>>>>>>>> vanished from interim update site ?
>>>>>>>> Cheers,
>>>>>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618032 is a reply to message #122344] Tue, 13 May 2008 10:59 Go to previous message
a replacement
> Hi everyone,
> Cheers,
> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618033 is a reply to message #122355] Tue, 13 May 2008 11:17 Go to previous message
Hi Guillaume,
gr. Martin
> as a replacement
>> Hi everyone,
>> Cheers,
>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618040 is a reply to message #122364] Wed, 14 May 2008 02:54 Go to previous message
Hi Martin,
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> gr. Martin
>> as a replacement
>>> Hi everyone,
>>> Cheers,
>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618041 is a reply to message #122441] Wed, 14 May 2008 03:05 Go to previous message
> Hi Martin,
> Cheers,
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>> feature.
>>>> Hi everyone,
>>>> Cheers,
>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618044 is a reply to message #122451] Wed, 14 May 2008 06:43 Go to previous message
Hi Guillaume,
gr. Martin
>> Hi Martin,
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> it.
>>> gr. Martin
>>>> feature.
>>>>> Hi everyone,
>>>>> Cheers,
>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618050 is a reply to message #122481] Fri, 16 May 2008 08:14 Go to previous message
Hi Martin,
Can you fix this ?
Guillaume
Martin Taal wrote:
> Hi Guillaume,
> gr. Martin
>>> Hi Martin,
>>> Cheers,
>>> Guillaume
>>> Martin Taal wrote:
>>>> Hi Guillaume,
>>>> should get it.
>>>> gr. Martin
>>>>> feature.
>>>>>> Hi everyone,
>>>>>> Cheers,
>>>>>> Guillaume
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618053 is a reply to message #122538] Fri, 16 May 2008 10:08 Go to previous message
Hi Guillaume,
gr. Martin
> Hi Martin,
> Can you fix this ?
> Cheers,
> Guillaume
> Martin Taal wrote:
>> Hi Guillaume,
>> gr. Martin
>>>> Hi Martin,
>>>> Cheers,
>>>> Guillaume
>>>> Martin Taal wrote:
>>>>> Hi Guillaume,
>>>>> should get it.
>>>>> gr. Martin
>>>>>> feature.
>>>>>>> Hi everyone,
>>>>>>> Cheers,
>>>>>>> Guillaume
The Netherlands
Re: org.eclipse.emf.teneo.hibernate has vanished from update site ? [message #618056 is a reply to message #122562] Fri, 16 May 2008 11:25 Go to previous message
Nick
Martin Taal wrote:
> Hi Guillaume,
> about that.
> gr. Martin
>> Hi Martin,
>> Can you fix this ?
>> Cheers,
>> Guillaume
>> Martin Taal wrote:
>>> Hi Guillaume,
>>> gr. Martin
>>>>> Hi Martin,
>>>>> Cheers,
>>>>> Guillaume
>>>>> Martin Taal wrote:
>>>>>> Hi Guillaume,
>>>>>> should get it.
>>>>>> gr. Martin
>>>>>>> feature.
>>>>>>>> Hi everyone,
>>>>>>>> Cheers,
>>>>>>>> Guillaume
Previous Topic:[CDO 0.8.0 M7] unknow error / problem
Next Topic:comparison of *.xmi via EMF Compare not possible
Current Time: Mon Jul 21 21:57:58 EDT 2025
Powered by FUDForum. Page generated in 0.60992 seconds
