| Can't see welome screen [message #122336] |
Wed, 07 December 2005 17:15 |
I've installed eclipse 3.1.1. The only problem is that when I do Help >
Welcome the welcome screen/window is blank. The welcome just shows white.
My JDK is 1.5.0_05. My OS is Windows XP pro. Has anyone had this problem
and a fix? Below is a copy of my config.ini. Is there anything I'm missing
or not doing?
Send a responce in addition to crh@panix.com
Thank you.
####################################### Begin
# Eclipse runtime configuration file
# This file contains a number of key/value pairs that are merged into the
# System properties on system startup. The values control the way the
# runtime is structured and runs.
# Note: Only platform:/base/ and file: URLs are supported. In general
the
# URLs given may include a version number (e.g., .../location_1.2.3).
# If a version is not specified, the system binds
# to the location which matches exactly or to the versioned location with
the
# latest version number. If a version number is given then only exact
matches
# are considered.
# The URL for the runtime entry point. The default value is
# platform:/base/plugins/org.eclipse.osgi
#osgi.framework = platform:/base/plugins/org.eclipse.osgi
# The classpath for the framework found at the osgi.framework location.
This
# comma-separated list contains either URLs or simple element names.
Simple
# names are assumed to be relative to the framework's install directory.
# Typically this value need not be set as it is initialized by the
framework itself.
# Version match searching is not done for URLs listed here.
#osgi.frameworkClassPath =
# The comma-separated list of locations to search for the splash screen
file (splash.bmp).
# For each list element a subdirectory structure based on the pattern
nl/<locale> is searched.
# The system binds to the first matching file. There is no default value.
osgi.splashPath = platform:/base/plugins/org.eclipse.platform
# The location of the splash screen file. If this value is set at system
startup it is used
# in favour of the osgi.splashPath searching outlined above. If the value
is not set
# the searching is done and this key is bound to the result of the search.
#osgi.splashLocation =
# The comma-separated list of bundles which are automatically installed
and optionally started
# once the system is up and running. Each entry if of the form
# <URL | simple bundle location>[@ [<startlevel>] [":start"]]
# If the startlevel is omitted then the framework will use the default
start level for the bundle.
# If the "start" tag is added then the bundle will be marked as started
after being installed.
# Simple bundle locations are interepreted as relative to the framework's
parent directory.
# The startlevel indicates the OSGi start level at which the bundle should
run.
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
# The product to run. A given Eclipse configuration may contain many
products.
# The product identified will supply the branding (window icons, title bar
text) etc
# as well as define the default application to run.
eclipse.product=org.eclipse.sdk.ide
# The application to run. The value specified here is the id of the
application extension
# the runtime will find, instantiate and execute once the system is up.
Note that typically
# the identified eclipse.product defines the default application to run.
#eclipse.application=
# The default workspace location
osgi.instance.area.default=@user.home/workspace
# The build identifier
eclipse.buildId=M20050929-0840
# End of file marker - must be here
eof=eof
############################################## End ########################
FUDForum. Page generated in 0.08379 seconds
