Home » Modeling » GMF (Graphical Modeling Framework) » Accessing programatically a property of a model element ??
Accessing programatically a property of a model element ?? [message #122305] Fri, 27 April 2007 09:40 Go to next message
Originally posted by: renwart.lippmann.lu
Hi everybody,
I'd like to know the best way to access (and modify) some properties of
a model element programatically. I suppose these changes will probably
occur in the project "*.diagram" ...
I'm new in GMF and I don't know the best way to access my model element
from this project ...
Thanks in advance for any help.
benren.
Re: Accessing programatically a property of a model element ?? [message #122455 is a reply to message #122305] Sat, 28 April 2007 09:12 Go to previous message
Originally posted by: newsgroups.elmarweber.org
Hello Ben,
That depends partly on when/where you want to modify the properties?
E.g.: If you need to access them in the *EditPart classes you can access
the notation model elements via #getPrimaryView() and your model element
with #getPrimaryView().getElement().
ciao,
elm
Previous Topic:Getting editing domain from a menu
Next Topic:Avoiding Code Generation when building metamodels
Current Time: Fri Nov 14 16:04:06 EST 2025
Powered by FUDForum. Page generated in 0.03608 seconds
