Home » Archived » BIRT » Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)?
| Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)? [message #122293] |
Tue, 31 January 2006 20:28  |
Originally posted by: rrachamallu.hotmail.com
I have a line chart, I want to define a trigger to show the tool tip when
the user moves the mouse pointer over the Value(Y) Series data points. First
I need to figure out the function in which I need to set up the trigger. I
tried the "beforeGeneration" function with out success.
I checked the code examples in org.eclipse.birt.chart.examples plugin.
Still I am unable to make this work. If you have an example that you can
share, it will be great.
Reddy
| Re: Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)? [message #122807 is a reply to message #122491] |
Wed, 01 February 2006 12:51   |
Hi David,
There is no problem with the examples plugin.
I could also set the tooltip using the designer. What I am trying to do is
to set the tooltip using JavaScript. I am doing this as an excercise before
writing more complicated event handlers.
Here is what I tried (based on the code from example plugin)
Attempt 1:
function beforeDrawSeries( series, seriesRenderer, context )
series.getTriggers( ).add( TriggerImpl.create(
TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create( ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create( 200, "abc" ) ) ) );
Attempt 2:
function beforeGeneration( chart, context )
var series = chart.getSeriesForLegend().getDesignTimeSeries();
Both of these did not work. Your feedback will be greatly appreciated.
Reddy
PS: I just registered for the "BIRT In Depth" class at eclipsecon 2006
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:drpr0a$pvi$1@utils.eclipse.org...
> Hi Reddy,
> What's the problem with the examples plugin? There is a tooltip example
> there.
> David
> "Reddy Rachamallu" <rrachamallu@hotmail.com> wrote in message
> news:drp2j4$nn7$1@utils.eclipse.org...
>> when the user moves the mouse pointer over the Value(Y) Series data
>> points. First I need to figure out the function in which I need to set up
>> the trigger. I tried the "beforeGeneration" function with out success.
>> Thanks
>> Reddy
| Re: Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)? [message #122885 is a reply to message #122807] |
Wed, 01 February 2006 15:53   |
The importPackage is missing to access some classes. When you reference a
Java class inside JavaScript code, you need to import its package.
So change the function to:
importPackage(Packages.org.eclipse.birt.chart.model.data.imp l);
importPackage(Packages.org.eclipse.birt.chart.model.attribut e);
importPackage(Packages.org.eclipse.birt.chart.model.attribut e.impl);
Unfortunately the tooltip value gets overriden by the value of the
datapoint. You can file a bug in bugzilla for this, if a value is set, we
should not override it. http://bugs.eclipse.org/bugs . I hope it's not a big
issue for you, it has gone unnoticed since usually we do not set the same
tooltip for all the datapoint values, and this script+interactivity scenario
where you could put a different tooltip for each point based on some
scripting logic was not taken into account.
David
news:drqs6a$r1h$1@utils.eclipse.org...
> Hi David,
> is to set the tooltip using JavaScript. I am doing this as an excercise
> before writing more complicated event handlers.
> Attempt 1:
> Attempt 2:
> Thanks
> Reddy
>> Hi Reddy,
>> there.
>> Thanks,
>> David
>>> Hi,
>>> up the trigger. I tried the "beforeGeneration" function with out
>>> success.
>>> Thanks
>>> Reddy
| Re: Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)? [message #125096 is a reply to message #122885] |
Tue, 07 February 2006 01:11   |
Hi David,
Thanks for the code. It worked.
Regarding the tooltip, it would have been nice if we could have a tooltip
that could take the data point add some formatting and then display it. But
it is not a show-stopper for me.
Reddy
news:drr73v$tnc$1@utils.eclipse.org...
> big issue for you, it has gone unnoticed since usually we do not set the
> same tooltip for all the datapoint values, and this script+interactivity
> scenario where you could put a different tooltip for each point based on
> some scripting logic was not taken into account.
> David
>> Hi David,
>> Attempt 1:
>> Attempt 2:
>> Thanks
>> Reddy
>>> Hi Reddy,
>>> there.
>>> Thanks,
>>> David
>>>> Hi,
>>>> success.
>>>> can share, it will be great.
>>>> Thanks
>>>> Reddy
| Re: Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)? [message #125122 is a reply to message #125096] |
Tue, 07 February 2006 03:24   |
Hi Reddy,
There is such feature already, you don't even need to use scripting for
that. You can go to the Series interactivity dialog in the builder and set
the onmouseover/tooltip. The value of the tooltip is the label for the
datapoint (you can set invisible so that it shows only when hovering). The
formatting of your datapoint label applies to the tooltip.
David
news:ds9dcj$q1f$1@utils.eclipse.org...
> Hi David,
> But it is not a show-stopper for me.
> Thanks
> Reddy
>> Thanks,
>> David
>>> Hi David,
>>> Attempt 1:
>>> Attempt 2:
>>> Thanks
>>> Reddy
>>>> Hi Reddy,
>>>> there.
>>>> Thanks,
>>>> David
>>>>> Hi,
>>>>> success.
>>>>> plugin. Still I am unable to make this work. If you have an example
>>>>> that you can share, it will be great.
>>>>> Thanks
>>>>> Reddy
| Re: Any examples of JavaScript event handlers setting triggers for charts (Mouse Over etc)? [message #125555 is a reply to message #125122] |
Tue, 07 February 2006 12:59  |
Hi David,
Thanks. It works. I am now able to format the tooltips.
Reddy
news:ds9lf3$6bc$1@utils.eclipse.org...
> Hi Reddy,
> David
>> Hi David,
>> tooltip that could take the data point add some formatting and then
>> display it. But it is not a show-stopper for me.
>> Thanks
>> Reddy
>>> a Java class inside JavaScript code, you need to import its package.
>>> we should not override it. http://bugs.eclipse.org/bugs . I hope it's
>>> not a big issue for you, it has gone unnoticed since usually we do not
>>> set the same tooltip for all the datapoint values, and this
>>> script+interactivity scenario where you could put a different tooltip
>>> for each point based on some scripting logic was not taken into account.
>>> Thanks,
>>> David
>>>> Hi David,
>>>> do is to set the tooltip using JavaScript. I am doing this as an
>>>> excercise before writing more complicated event handlers.
>>>> Attempt 1:
>>>> Attempt 2:
>>>> Thanks
>>>> Reddy
>>>>> Hi Reddy,
>>>>> example there.
>>>>> Thanks,
>>>>> David
>>>>>> Hi,
>>>>>> set up the trigger. I tried the "beforeGeneration" function with out
>>>>>> success.
>>>>>> Thanks
>>>>>> Reddy
Current Time: Wed Nov 05 06:13:43 EST 2025
Powered by FUDForum. Page generated in 0.04388 seconds
