| Mobile phones support (Symbian) [message #122276] | Mon, 23 February 2009 06:13  |  |
| Eclipse User  |  |  |  |  | Originally posted by: peterka.jiri.gmail.com
 it seems Qooxdoo is unable to run at least on Symbian based mobile
 phones (E51). And it doesn't seems to be question of free memory. Only
 initial blue gradient screen appears. In OperaMini it gave me the same
 results.
 Is there anybody successful with running RAP/RWT/Qooxdoo application on
 Symbian mobile phones?
 Jiri
 PS: I've used latest rap-1.1.2-SR2-target-3.4 with qooxdoo 0.7.4
| Re: Mobile phones support (Symbian) [message #123434 is a reply to message #123395] | Mon, 02 March 2009 07:00   |  |
| Eclipse User  |  |  |  |  | Jiri,
 if you have an actual use case for OperaMini, you could ask on the
 qooxdoo mailing-list or open a bug there. I would be glad to
 integrate a version of qooxdoo that runs on mobile devices
 Rüdiger
 Jiri Peterka wrote:
 > unfortunately I didn't find a way how to get these information.
 > Anyway it seems OperaMini has really limited Ajax support - see
 >  http://dev.opera.com/articles/view/javascript-support-in-ope ra-mini-4/ .
 > Overall it seems like a browser problem, because there is the same
 > behaviour while running GWT-ext application for example. Maybe it can be
 > solved with some qooxdoo workaround or we can wait for next browser
 > generation (Nokia is working on some Webkit based browser for Symbian).
 > Regards
 > Jiri
 > Rüdiger Herrmann wrote:
 >> Hi Jiri,
 >> though I haven't it tried myself, this looks like a JavaScript error.
 >> Can you get any further information (e.g. from an error log in
 >> OperaMini)?
 >> Cheers,
 >> Rüdiger
 >> Jiri Peterka wrote:
 >>> Hi,
 >>> Only initial blue gradient screen appears. In OperaMini it gave me
 >>> the same results.
 >>> on Symbian mobile phones?
 >>> Thanks
 >>> Jiri
| Re: Mobile phones support (Symbian) [message #123751 is a reply to message #123434] | Tue, 03 March 2009 11:25  |  |
 Hi Rüdiger,
 I've created Bug in Qooxdoo Bugzilla
 (http://bugzilla.qooxdoo.org/show_bug.cgi?id=2033) for this. I've also
 done compatibility check with Android standard browser and it works fine
 (although it loads RAP page quite long). Nevertheless Opera Mini running
 on Android has the same problems as on Symbian phone. So there is quite
 no doubt that the limitations are on the browser side, not on the OS side.
 Jiri
 > Jiri,
 > qooxdoo mailing-list or open a bug there. I would be glad to integrate a
 > Cheers,
 > Rüdiger
 > Jiri Peterka wrote:
 >> be solved with some qooxdoo workaround or we can wait for next browser
 >> Regards
 >> Jiri
 >>> Hi Jiri,
 >>> OperaMini)?
 >>> Cheers,
 >>> Rüdiger
 >>> Jiri Peterka wrote:
 >>>> Hi,
 >>>> the same results.
 >>>> Thanks
 >>>> Jiri
FUDForum. Page generated in 0.05000 seconds
