Home » Newcomers » Newcomers » The CPU is not supported by selected debugger
The CPU is not supported by selected debugger [message #122258] Wed, 07 December 2005 11:59 Go to next message
Originally posted by: nospam.y.com
I'm trying to use eclipse to debug an application. I've built/debugged 32
bit applications before in eclipse but this is a 64 bit application. When
I try to select "GDB Debugger" as the Debugger, it indicates "The CPU is
not supported by selected debugger". I can use gdb to debug the
application from the terminal -- is there something I need to do in
eclipse to get it to work?
Re: The CPU is not supported by selected debugger [message #122449 is a reply to message #122258] Thu, 08 December 2005 12:57 Go to previous message
Originally posted by: xxxx.y.z
I didn't have the latest installed..nevermind..nothing to see here...it's
working great.
Previous Topic:java.lang.OutOfMemoryError: PermGen space
Next Topic:Upgrading WST 7.1 to 1.0RC1
Current Time: Sun Jul 27 12:42:40 EDT 2025
Powered by FUDForum. Page generated in 0.08633 seconds
