Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » jet editor java syntax coloring
jet editor java syntax coloring [message #122254] Sat, 10 May 2008 05:22 Go to next message
Dear All
I have just installed the jet editor from the emft in M7 and am pleasantly
delighted with the highlighting of the code it gives me. However, it only
syntax colors the jet code and not the embedded java. However,there seems
to be a menu item 'set non-jet text content colorer...' but this brings up
an empty list.... does anyone have further suggestion (information on
using and configuring the editor seems to be sparse on the ground'
Also, as an aside, I am trying to edit the ecore Class.javajet file and
various included files with the jet editor and it is complaining that it
can't identify the ecore genModel classes. How can I add these to the list
of classes it understands (note I am still building the java source files
with the emf jet installation)
regards
gary
Re: jet editor java syntax coloring [message #122266 is a reply to message #122254] Sat, 10 May 2008 15:17 Go to previous messageGo to next message
Gary,
It's best to ask about it on the M2T newsgroup, which I've added to the
"to" list of the reply...
I think the containing project needs to have codegen.ecore on the classpath.
gary thompson wrote:
> Dear All
> pleasantly delighted with the highlighting of the code it gives me.
> However, it only syntax colors the jet code and not the embedded java.
> However,there seems to be a menu item 'set non-jet text content
> colorer...' but this brings up an empty list.... does anyone have
> further suggestion (information on using and configuring the editor
> and various included files with the jet editor and it is complaining
> that it can't identify the ecore genModel classes. How can I add these
> to the list of classes it understands (note I am still building the
> java source files with the emf jet installation)
> regards
> gary
Re: jet editor java syntax coloring [message #122290 is a reply to message #122266] Mon, 12 May 2008 16:17 Go to previous messageGo to next message
Ed Merks wrote:
> Gary,
Dear Ed
Many thanks for (re)directing me to the right place. Just as an aside and
as a newbie trying to work out what goes with what and how the whole m2t,
emft, emf, m2t etc acronym soup holds together is quite confusing. For
example just one question (there are more) there seems to be jet and jet2
but will jet2 replace jet in the emf framework?
regards
gary
Re: jet editor java syntax coloring [message #122301 is a reply to message #122290] Mon, 12 May 2008 16:36 Go to previous message
Gary,
Comments below.
> Ed Merks wrote:
>> Gary,
>> the "to" list of the reply...
> Dear Ed
> and as a newbie trying to work out what goes with what and how the
> whole m2t, emft, emf, m2t etc acronym soup holds together is quite
> confusing.
It's wholesome and nourishing soup! :-P Don't worry, if you go to the
wrong place, I'll notice and send you to the right one, so it's not a
problem.
> For example just one question (there are more) there seems to be jet
> and jet2 but will jet2 replace jet in the emf framework?
That's the idea, yes, but we've not had time to do that work since to a
large extent it should be a big no-op.
> regards
> gary
Re: jet editor java syntax coloring [message #618024 is a reply to message #122254] Sat, 10 May 2008 15:17 Go to previous message
Gary,
> Dear All
> regards
> gary
Re: jet editor java syntax coloring [message #618026 is a reply to message #122266] Mon, 12 May 2008 16:17 Go to previous message
Ed Merks wrote:
> Gary,
Dear Ed
regards
gary
Re: jet editor java syntax coloring [message #618027 is a reply to message #122290] Mon, 12 May 2008 16:36 Go to previous message
Gary,
Comments below.
> Ed Merks wrote:
>> Gary,
> Dear Ed
> confusing.
problem.
> regards
> gary
Previous Topic:[Teneo] Unique Id generation size
Next Topic:[Teneo] Unique Id generation size
Current Time: Tue Dec 02 18:15:42 EST 2025
Powered by FUDForum. Page generated in 0.04543 seconds
