| Re: Vista / Server 2008 problems in server side eclipse [message #122118 is a reply to message #121967] |
Wed, 03 December 2008 03:37  |
Carsten Spieker schrieb:
> NOTE: The same configuration started in the eclipse IDE does NOT cause these
> problems, only if started in a web server.
Are both using the same JRE and path configuration? I could imaging that
some GDI+ library is not correctly loaded or some other stuff is not
setup. That's why drawing is missing something.
To eliminate the servlet bridge or Tomcat as a problem I would try to
create a command line wrapper which leaves the HTTP communication out
for now. That could read a figure and write a file. If that also exposes
the same issue, we know it's not the servlet bridge or Tomcat. I know
this doesn't solved the issue but it helps in tracking it down.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
FUDForum. Page generated in 0.07198 seconds
