| [ds] Getting a lock required more than 10000 ms [message #121913] |
Fri, 28 November 2008 15:11  |
Originally posted by: ekkehard.gentz-software.de
I'm getting this warning -
but not every run - sometimes it runs without any problem
WARNING - 21:03:50 [B: org.eclipse.equinox.ds] - Getting a lock required
more than 10000 ms. There might be a synchronization problem in this
callstack or just the build/dispose process of some components took too
long!.
can I configure this timeout-value ?
thx
ekke
Exception: Debug stacktrace
java.lang.Exception: Debug stacktrace
org.eclipse.equinox.internal.ds.InstanceProcess.getLock(Inst anceProcess.java:117)
org.eclipse.equinox.internal.ds.InstanceProcess.buildCompone nts(InstanceProcess.java:158)
at org.eclipse.equinox.internal.ds.Resolver.getEligible(Resolve r.java:317)
org.eclipse.equinox.internal.ds.SCRManager.serviceChanged(SC RManager.java:213)
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:91)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1248)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1563)
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1538)
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.register(ServiceRegistrationImpl.java:122)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:666)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:617)
org.ow2.easybeans.osgi.component.EZBComponentServiceFactory. updateMapsAndRegisterService(EZBComponentServiceFactory.java :219)
org.ow2.easybeans.osgi.component.EZBComponentServiceFactory. updated(EZBComponentServiceFactory.java:198)
org.eclipse.equinox.internal.cm.ManagedServiceFactoryTracker $2.run(ManagedServiceFactoryTracker.java:177)
org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(Se rializedTaskQueue.java:36)
FUDForum. Page generated in 0.05789 seconds
