Home » Archived » BIRT » 3-D pie Charts
3-D pie Charts [message #121911] Tue, 31 January 2006 14:37 Go to next message
Originally posted by: cchopra.executivehealthexams.com
I need to use 3D pie charts in my reports. Iam using BIRT 2.0 RC. I read
in the documentation that chart API supports 3D attribute for BAR , LINE
and AREA charts. Does the API support the 3D attribute for pie charts? If
it doesnt, is there other means to accomplish this.
Chandrika
Re: 3-D pie Charts [message #121980 is a reply to message #121911] Tue, 31 January 2006 15:31 Go to previous messageGo to next message
Pie Chart support 2D with depth, which has a 3D look, but is not "real" 3D
in a sense where there is no lighting computations or Z-sorting done. Please
take a look at some 2D with depth pie charts, I think it should be enough
for what you need. Otherwise please let me know exactly what you're looking
for.
I'm attaching one 2D with depth Pie Chart here for you, so you can see.
David Michonneau
BIRT Chart Lead
"chandrika" <cchopra@executivehealthexams.com> wrote in message
news:5ff298b916ddc9ed5fab669fd8fc6f91$1@www.eclipse.org...
> Hi
> Thanks
> Chandrika
Re: 3-D pie Charts [message #122034 is a reply to message #121980] Tue, 31 January 2006 15:55 Go to previous messageGo to next message
Hi David,
Thanks David.
We have our existing reports that has lot of 3D pie charts. I am
converting these to BIRT reports. I have tried the 2D with depth, which
really looks nice. But we still need to use the 3D pie charts.
Any suggestion how to do this.
Chandrika
Re: 3-D pie Charts [message #122047 is a reply to message #122034] Tue, 31 January 2006 16:08 Go to previous messageGo to next message
Hi Chandrika,
Can you post a screenshot of how your 3D pie chart look? How is it different
from the 2d with depth pie chart?
David
news:7807cb773171931d409c34b617adee12$1@www.eclipse.org...
> Hi David,
> Thanks David. We have our existing reports that has lot of 3D pie charts.
> I am converting these to BIRT reports. I have tried the 2D with depth,
> which really looks nice. But we still need to use the 3D pie charts.
> Thanks
> Chandrika
Re: 3-D pie Charts [message #122073 is a reply to message #122047] Tue, 31 January 2006 16:13 Go to previous messageGo to next message
For instance you can also change the pie ratio and series depth to give more
3D effect:
Is that what are you're trying to do?
David
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:drojjr$24e$1@utils.eclipse.org...
> Hi Chandrika,
> different
> David
>> Hi David,
>> Thanks
>> Chandrika
Re: 3-D pie Charts [message #122282 is a reply to message #122073] Tue, 31 January 2006 19:42 Go to previous messageGo to next message
Hi David,
I have a snapshot of the 3D chart. Can you reply to
cchopra@executivehealthexams.com so that i can send it to you. Iam using
the WebNewsReader and dont see the option to send the attachment
Chandrika
Re: 3-D pie Charts [message #122304 is a reply to message #122073] Tue, 31 January 2006 20:36 Go to previous messageGo to next message
Hi David,
Is there a way to change only the series depth color? I want to make it
gray for all. Changing the pie ratio and series depth did make it look
closer to the 3D one.
Chandrika
Re: 3-D pie Charts [message #122548 is a reply to message #122304] Wed, 01 February 2006 04:40 Go to previous message
Yes, you can force the depth color to be grey by using gradients in your
palette instead of plain colors. I sent you a screenshot at your email
address.
David
news:ce62dad6dc778b80fe2410ccbdc6ad9b$1@www.eclipse.org...
> Hi David,
> Thanks
> Chandrika
Previous Topic:ODA OU Plugin wizards
Next Topic:trap csv file before it's sent?
Current Time: Tue Nov 04 03:26:37 EST 2025
Powered by FUDForum. Page generated in 0.06316 seconds
