Home » Eclipse Projects » Remote Application Platform (RAP) » GridLayout difference with RCP
GridLayout difference with RCP [message #121876] Wed, 18 February 2009 11:24 Go to next message
Hi all,
Like almost everybody, I want to use the same code in RAP and RCP.
I'm working on a editor with Forms, Section and Table using GridLayout and
I do not have the same display in RCP and RAP (RCP result is the one I
also want on RAP).
Am I missing something ?
Loïc
Here is the code :
public class LayoutEditor extends EditorPart
private ManagedForm managedForm;
public void createPartControl(Composite parent)
FormToolkit toolkit = new FormToolkit(parent.getDisplay());
managedForm = new ManagedForm(toolkit, toolkit
.createScrolledForm(parent));
managedForm.getForm().setText("Title");
GridLayout layout = new GridLayout();
layout.marginWidth = 2;
managedForm.getForm().getBody().setLayout(layout);
Section paramSection = toolkit.createSection(managedForm.getForm()
.getBody(), Section.TITLE_BAR | Section.TWISTIE
| Section.CLIENT_INDENT);
paramSection.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false,
false));
paramSection.setText("param section");
paramSection.addExpansionListener(new ExpansionAdapter()
public void expansionStateChanged(ExpansionEvent e)
managedForm.getForm().reflow(true);
Composite paramSectionClient =
toolkit.createComposite(paramSection,
SWT.NONE);
paramSection.setClient(paramSectionClient);
paramSectionClient.setLayout(new GridLayout());
Section resultSection = toolkit.createSection(managedForm.getForm()
resultSection.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false,
false));
resultSection.setText("result section");
resultSection.addExpansionListener(new ExpansionAdapter()
toolkit = new FormToolkit(resultSection.getDisplay());
Composite sectionClient = toolkit.createComposite(resultSection,
SWT.NONE);
resultSection.setClient(sectionClient);
sectionClient.setLayout(new GridLayout());
final Tree tree = new Tree(paramSectionClient, SWT.BORDER);
tree.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
for (int i = 0; i < 4; i++)
TreeItem iItem = new TreeItem(tree, 0);
iItem.setText("TreeItem (0) -" + i);
for (int j = 0; j < 4; j++)
TreeItem jItem = new TreeItem(iItem, 0);
jItem.setText("TreeItem (1) -" + j);
for (int k = 0; k < 4; k++)
TreeItem kItem = new TreeItem(jItem, 0);
kItem.setText("TreeItem (2) -" + k);
for (int l = 0; l < 4; l++)
TreeItem lItem = new TreeItem(kItem, 0);
lItem.setText("TreeItem (3) -" + l);
for (int m = 0; m < 4; m++)
TreeItem mItem = new TreeItem(lItem, 0);
mItem.setText("TreeItem (3) -" + l);
Composite gridComposite = toolkit.createComposite(sectionClient,
SWT.NONE);
gridComposite.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false,
false));
gridComposite.setLayout(new GridLayout(1, true));
final ScrolledForm form =
toolkit.createScrolledForm(gridComposite);
form.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false, false));
form.getBody().setLayout(new GridLayout());
Section section = toolkit.createSection(form.getBody(),
Section.TITLE_BAR | Section.TWISTIE | Section.CLIENT_INDENT
| Section.EXPANDED);
section.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false,
false));
section.addExpansionListener(new ExpansionAdapter()
form.reflow(true);
Composite composite = toolkit.createComposite(section, SWT.NONE);
composite.setLayout(new GridLayout(1, true));
section.setClient(composite);
Composite gridTableComposite = toolkit.createComposite(composite,
SWT.NONE);
gridTableComposite.setLayoutData(new GridData(SWT.FILL, SWT.FILL,
false, false));
gridTableComposite.setLayout(new GridLayout(1, true));
Composite borderComp = new Composite(gridTableComposite, SWT.NONE);
borderComp.setBackground(IhmUtilHolder.getIhmUtil().getColor (
borderComp, 0, 0, 0));
borderComp
false));
GridLayout gridLayout = new GridLayout();
gridLayout.marginBottom = -3;
gridLayout.marginTop = -3;
gridLayout.marginLeft = -3;
gridLayout.marginRight = -3;
borderComp.setLayout(gridLayout);
Table table = new Table(borderComp, SWT.MULTI | SWT.BORDER
| SWT.FULL_SELECTION);
table.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false,
false));
table.setLinesVisible(true);
table.setHeaderVisible(true);
String[] titles =
{ " ", "C", "!", "Description", "Resource", "In Folder",
"Location",
"Location", "Location" };
for (int i = 0; i < titles.length; i++)
TableColumn column = new TableColumn(table, SWT.NONE);
column.setText(titles[i]);
for (int i = 0; i < 100; i++)
TableItem item = new TableItem(table, SWT.NONE);
item.setText(0, "x");
item.setText(1, "y");
item.setText(2, "!");
item.setText(3, "this stuff behaves the way I expect");
item.setText(4, "almost everywhere");
item.setText(5, "some.folder");
item.setText(6, "line " + i + " in nowhere");
item.setText(7, "line " + i + " in nowhere");
item.setText(8, "line " + i + " in nowhere");
table.getColumn(i).pack();
public void doSave(IProgressMonitor monitor)
// TODO Auto-generated method stub
public void doSaveAs()
public void init(IEditorSite site, IEditorInput input)
throws PartInitException
setSite(site);
setInput(input);
public boolean isDirty()
return false;
public boolean isSaveAsAllowed()
return false;
public void setFocus()
Re: GridLayout difference with RCP [message #121927 is a reply to message #121876] Wed, 18 February 2009 14:54 Go to previous messageGo to next message
Hi Loïc,
> and I do not have the same display in RCP and RAP (RCP result is the one
> I also want on RAP).
I guess it is unlikely that anyone reading here has the time to analyze
your code to find out what exactly the problem is you experience. You
should rather try to describe the difference and/or provide screenshots.
In general, there is no difference between layouts in RAP and in RCP -
in fact, it's the exact same code. What might cause a different
appearance is that certain widgets may have slightly different preferred
sizes, due to different font sizes etc. Anyway, you should try to narrow
down the problem.
Ralf
> Here is the code :
> @Override
> false));
> @Override
> Composite paramSectionClient = toolkit.createComposite(paramSection,
> SWT.NONE);
> false));
> @Override
> SWT.NONE);
> SWT.NONE);
> false));
> final ScrolledForm form = toolkit.createScrolledForm(gridComposite);
> | Section.EXPANDED);
> false));
> form.reflow(true);
> SWT.NONE);
> false, false));
> borderComp
> false));
> table.setLayoutData(new GridData(SWT.FILL, SWT.FILL, false, false));
> String[] titles =
> { " ", "C", "!", "Description", "Resource", "In Folder", "Location",
> @Override
> @Override
> @Override
> setSite(site);
> setInput(input);
> @Override
> return false;
> @Override
> return false;
> @Override
Re: GridLayout difference with RCP [message #121940 is a reply to message #121927] Wed, 18 February 2009 17:46 Go to previous messageGo to next message
Thanks Ralf for your answer.
First, how can I add screenshot via the Eclipse NewsPortal ?
Then I will try to describe the differences :
I have a ScrolledForm with a Section. Everybody have GridLayout / GridData
with SWT.FILL and Grab excess to false.
In the Section I have a Table with several rows and columns.
In RCP the table is well displayed with scrollbar on the editor to see all
of it.
In RAP the table is really small, the same width as the section title (so
only one column can be see) and the height to see one row. I have
scrollbar on the table to see other columns / rows.
It may be more explicit with screenshot (if someone can help me to provide
them...)
Loïc
Ralf Sternberg wrote:
> Hi Loïc,
> down the problem.
> Best regards,
> Ralf
Re: GridLayout difference with RCP [message #121978 is a reply to message #121940] Thu, 19 February 2009 03:38 Go to previous messageGo to next message
You can simply add it to your Newsgroup posting as many others did
before (e.g. MenuBar property "menuBarShellClientArea" not preserved)
This works fine with Thunderbird, for instance.
Stefan.
Re: GridLayout difference with RCP [message #121991 is a reply to message #121978] Thu, 19 February 2009 04:20 Go to previous messageGo to next message
Unfortunately, I can't use Thunderbird or other news reader... I only have
Eclipse NewsPortal.
Here are two link with screenshots :
RCP : http://f.imagehost.org/0869/RCP.jpg
RAP : http://g.imagehost.org/0004/RAP.jpg
> Stefan.
Re: GridLayout difference with RCP [message #122003 is a reply to message #121991] Thu, 19 February 2009 04:47 Go to previous messageGo to next message
have you tried to replace
with
when creating the table and its parent composites?
However, if exactly the same code layouts different in RCP and RAP, this
is probably a bug.
Stefan.
> have Eclipse NewsPortal.
>> Regards,
>> Stefan.
Re: GridLayout difference with RCP [message #122015 is a reply to message #122003] Thu, 19 February 2009 05:02 Go to previous messageGo to next message
Thanks you for looking at my screenshots.
Yes, it's exactly the same code. Is it possible to consider this bug ?
I've tried with grabExcess to true like you say and in RAP the table take
indeed all the editor available space. However, if there is not enough
space, the horizontal scrollbar is created on the table (instead of on the
editor in RCP).
Moreover in RCP, when I increase the editor horizontally, the table also
increase its last column width to fill all the space (and I want my table
to always keep its minimum size).
Loïc
Stefan Roeck wrote:
> with
> is probably a bug.
> Stefan.
Re: GridLayout difference with RCP [message #122042 is a reply to message #122015] Thu, 19 February 2009 05:19 Go to previous messageGo to next message
Hi Loïc,
> take indeed all the editor available space. However, if there is not
> enough space, the horizontal scrollbar is created on the table (instead
> of on the editor in RCP).
> table to always keep its minimum size).
The problem is that the Table#computeSize() method obviously returns the
default 64x64 px (plus some px for the border). With this shortcoming,
it's not possible to get the "minimum" size for the Table. You'll have
to find a workaround, like Stefan suggested. Sorry for that.
I reopened bug 223895: [Table] Revise Table#computeSize()
https://bugs.eclipse.org/bugs/show_bug.cgi?id=223895
Regards, Ralf
Re: GridLayout difference with RCP [message #122070 is a reply to message #122042] Fri, 20 February 2009 04:58 Go to previous messageGo to next message
Thanks for your answer Ralf.
Do you have a Target Milestone for this bug fixing ?
It's currently set to 1.2 M2...
Loïc
> Regards, Ralf
Re: GridLayout difference with RCP [message #122094 is a reply to message #122070] Fri, 20 February 2009 05:45 Go to previous messageGo to next message
--------------060605010908080909020807
Hi Lo
Re: GridLayout difference with RCP [message #122108 is a reply to message #122094] Fri, 20 February 2009 06:39 Go to previous messageGo to next message
Hi Ivan,
I use v1.1.1.
I will try in a view instead of an editor. But my target is the editor.
Do you know why there is such a different behaviour according to the
container (view vs editor) ?
Loïc
Ivan Furnadjiev wrote:
> Hi Loïc,
> which version of RAP do you use? v1.1.1? CVS HEAD? Do you use the CVS
> HEAD from the new location "/cvsroot/rt" and not from the old
> "/cvsroot/technology"? My test snippet is attached. It is exactly the
> same code as yours but in the view. The table and Tree size is OK.
> Best,
> Ivan
Re: GridLayout difference with RCP [message #122122 is a reply to message #122108] Fri, 20 February 2009 06:55 Go to previous messageGo to next message
Hi Loïc,
the reason for your problems is using the RAP version 1.1.1. The bug
that Ralf reopened is marked as fixed in 1.2M2.
Use the target platform 1.2M2 or higher. Latest target platform is 1.2M5
and can download it from:
http://www.eclipse.org/rap/downloads/
Best,
Ivan
> Hi Ivan,
> I use v1.1.1.
> Loïc
>> Hi Loïc,
>> Best,
>> Ivan
Re: GridLayout difference with RCP [message #122159 is a reply to message #122122] Fri, 20 February 2009 10:45 Go to previous messageGo to next message
Great, thank you Ivan, it works perfectly !
I should have tried last milestone sooner...
Loïc
> Hi Loïc,
> Best,
> Ivan
Re: GridLayout difference with RCP [message #122172 is a reply to message #122159] Fri, 20 February 2009 11:11 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
just a little comment, you should consider checking http://www.eclipse.org/rap/noteworthy/ regularly. there you can see what the milestones bring with them and the fixed bugs, then you'll see why it
is most recommendable to use the latest milestone release :).
Greetings,
Ben
> Loïc
>> Hi Loïc,
>> 1.2M5 and can download it from:
>> Best,
>> Ivan
Re: GridLayout difference with RCP [message #122197 is a reply to message #122172] Fri, 20 February 2009 12:34 Go to previous message
Yes, I'm sorry, I should have tried with the lastest milestone.
However I won't use it because my application may be released soon and I
need a stable version. I hope it won't be so soon so I could integrated
1.2.0 final version in June.
Loïc
Ben W. wrote:
> Greetings,
> Ben
Previous Topic:Databinding missing class
Next Topic:Migrate RAP theme from property to css
Current Time: Sat Jul 26 10:39:25 EDT 2025
Powered by FUDForum. Page generated in 1.08406 seconds
