Home » Eclipse Projects » Remote Application Platform (RAP) » Qooxdoo and RAP
Qooxdoo and RAP [message #121760] Tue, 17 February 2009 15:27 Go to next message
Originally posted by: freddan85.gmail.com
Hi!
I'm developing a RAP application which, among other things, will contain
of two trees that supports drag and drop between each other. Since RAP
doesn't have support for drag and drop, I've made a custom widget using
the qooxdoo 0.7.4 API. I've managed to get the widget working by using
"regular trees" (qx.ui.tree.Tree), but I want the more user-friendly
VirtualTree (qx.ui.treevirtual.TreeVirtual). However, when I try to
declare a virtual tree I get the following error at runtime:
"Could not evaluate javascript response:
TypeError: qx.ui.treevirtual is undefined"
Is there any limitations in the qooxdoo api, or why isn't the
treevirtual working when the regular tree works fine?
I've looked at the code in qooxdoos demo browser, but I can't get it to
work even with their code. Their demo can be found at
http://demo.qooxdoo.org/0.7.4/demobrowser/#example~TreeVirtu al_6.html
Thanks for any help!
Re: Qooxdoo and RAP [message #121799 is a reply to message #121760] Wed, 18 February 2009 03:08 Go to previous message
I suppose that's because RAP doesn't contain all qooxdoo classes but
only those that are needed (to keep the qx lib small). You can look at
org.eclipse.rap.rwt.q07 to check the contained classes.
However, it should be possible to add additional qx classes using the
org.eclipse.rap.ui.resources extension point.
Stefan.
Fredrik Häggbom schrieb:
> Hi!
Previous Topic:Unhandled accelerator keycodes
Next Topic:Typo on project plan page?
Current Time: Wed Nov 19 04:53:12 EST 2025
Powered by FUDForum. Page generated in 0.03545 seconds
