Home » Newcomers » Newcomers » How to Run from Linux?
How to Run from Linux? [message #121646] Sun, 04 December 2005 21:26 Go to next message
Originally posted by: rogerbayarea.yahoo.com
Newbie, need to know how to run from Linux? I've been searching and I can
only see for windows base.
Could someone help me.
Re: How to Run from Linux? [message #121675 is a reply to message #121646] Sun, 04 December 2005 22:40 Go to previous messageGo to next message
Originally posted by: weconsul.ptd.net
> can only see for windows base.
There ia a guide here
http://www.cs.umanitoba.ca/~eclipse/1-Install.pdf
It is at the end of the PDF.
or
http://saloon.javaranch.com/cgi-bin/ubb/ultimatebb.cgi?ubb=g et_topic&f=13&t=001386
There is other documentation out on the Internet. Just google for
"Installing Eclipse on Linux"
I am on windows. Should be the same.
Make sure you have Java installed.
Download unzip and create a .Eclipse command to execute the Eclipse.exe
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: How to Run from Linux? [message #121981 is a reply to message #121675] Tue, 06 December 2005 01:30 Go to previous messageGo to next message
Thanks a lot and appreciate your help. Now I can jump-start to work on
phpeclipse .
Re: How to Run from Linux? [message #122006 is a reply to message #121981] Tue, 06 December 2005 02:38 Go to previous message
> phpeclipse .
That plugin is just as easy into install. You can use Eclipse's update
manager. Here is some information
http://www.plog4u.org/index.php/Developing_PHPeclipse:Develo ping_Process
Previous Topic:Configuring VE
Next Topic:Which one of news groups is relating to OSGi?
Current Time: Sat Nov 08 21:35:20 EST 2025
Powered by FUDForum. Page generated in 0.08011 seconds
