| Abstract Schema [message #927] |
Fri, 13 September 2002 16:58  |
Originally posted by: troynet+web.ugcs.net
What is going to be the relationship between the IBM (soon to be Eclipse)
XML Schema Infoset API with the DOM 3 Abstract Schemas?
I could be completely misunderstanding everything, but it seems to me that
they overlap in purpose and functionality with Abstract Schemas offering a
superset.
| Re: Abstract Schema [message #957 is a reply to message #927] |
Fri, 13 September 2002 18:07  |
--------------5D348A7CBD532D09FAA71C38
Content-Type: text/plain; charset=us-ascii
Troy,
I take your question to indicate that you weren't aware of this announcement?
http://lists.w3.org/Archives/Public/www-dom/2002JulSep/0010. html
It wasn't so easy to spot among all the links...
The DOM work is focusing mainly on supporting PSVI and supporting both DTD and
XML Schema. Editing support for XML Schema is not a stated goal.
XSD fills this spacious niche by supporting the full abstract component model
of parts 1 and 2 of the Spec, in all it's carefully authored detail. It also
provides a rich editing model for representing the XML concrete syntax of XML
Schema and for supporting bottom up construction of abstract components. The
intent is to complement the DOM work.
> superset.
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Troy,
<p>I take your question to indicate that you weren't aware of this announcement?
<blockquote><a href=" http://lists.w3.org/Archives/Public/www-dom/2002JulSep/0010. html"> http://lists.w3.org/Archives/Public/www-dom/2002JulSep/0010. html</a></blockquote>
<p>The DOM work is focusing mainly on supporting PSVI and supporting both
DTD and XML Schema. Editing support for XML Schema is not a stated
goal.
<p>XSD fills this spacious niche by supporting the full abstract component
model of parts 1 and 2 of the Spec, in all it's carefully authored detail.
It also provides a rich editing model for representing the XML concrete
syntax of XML Schema and for supporting bottom up construction of abstract
components. The intent is to complement the DOM work.
<br>
<p>Troy Bridoux wrote:
<blockquote TYPE=CITE>What is going to be the relationship between the
<br>XML Schema Infoset API with the DOM 3 Abstract Schemas?
<p>I could be completely misunderstanding everything, but it seems to me
that
<br>they overlap in purpose and functionality with Abstract Schemas offering
a
<br>superset.</blockquote>
</html>
--------------5D348A7CBD532D09FAA71C38--
| Re: Abstract Schema [message #562425 is a reply to message #927] |
Troy,
> superset.
<html>
Troy,
goal.
<br>
that
a
</html>
FUDForum. Page generated in 0.03374 seconds
