Home » Eclipse Projects » Equinox » Problems with p2-izing a product
Problems with p2-izing a product [message #121587] |
Tue, 25 November 2008 14:19  |
I'm unable to p2-ize a product, after about a week of "monkey see,
monkey do", and I'm convinced that there's something wrong in what I'm
doing.
I'm p2-izing my product using the following command line:
<java
classpath=" ${p2.eclipse.dir}/plugins/org.eclipse.equinox.launcher_${ecl ipse.launcher.version}.jar "
classname="org.eclipse.equinox.launcher.Main" timeout="30000000"
resultproperty="p2.build.exit.code" fork="true">
<arg line="-clean -consoleLog -debug -nosplash -nosplash
--launcher.suppressErrors" />
<arg line="-application org.eclipse.equinox.p2.director.app.application" />
<arg line="-flavor tooling" />
<arg line="-installIU ${p2.IU}" />
<!--arg line="-list" /-->
<arg line="-version ${p2.version}" />
<arg line="-p2.os ${p2.os}" />
<arg line="-p2.ws ${p2.ws}" />
<arg line="-p2.arch ${p2.arch}" />
<arg line="-roaming" />
<arg line="-profile TwistProfile" />
<arg line="-metadataRepository file:${build_directory}/repo/" />
<arg line="-artifactRepository file:${build_directory}/repo/" />
<arg line="-destination ${p2.director.install.path}" />
<arg line="-bundlepool ${p2.director.install.path}" />
<jvmarg line="-Declipse.p2.data.area=${p2.director.install.path}/p2 "/>
</java>
However the exec fails with a lot of errors:
[java] !SUBENTRY 1 org.eclipse.equinox.p2.core 2 0 2008-11-26
00:39:55.022
[java] !MESSAGE Error at line 10, column 91: Missing required
attribute in "repository": url
00:39:55.023
[java] !MESSAGE Error at line 10, column 91: Illegal value for
attribute "url" of element "repository": null
00:39:55.024
[java] !MESSAGE Error at line 11, column 91: Missing required
00:39:55.026
[java] !MESSAGE Error at line 11, column 91: Illegal value for
00:39:55.027
[java] !MESSAGE Error at line 12, column 90: Missing required
00:39:55.029
[java] !MESSAGE Error at line 12, column 90: Illegal value for
00:39:55.030
[java] !MESSAGE Error at line 13, column 90: Missing required
00:39:55.032
[java] !MESSAGE Error at line 13, column 90: Illegal value for
[java]
[java] !ENTRY org.eclipse.equinox.p2.director.app 4 0 2008-11-26
00:41:43.818
[java] !MESSAGE The installable unit
com.thoughtworks.twist.eclipse.ui.product has not been found.
[java] The installable unit
[java] Java Result: 13
The installation unit "com.thoughtworks.twist.eclipse.ui.product"
however does exist and is listed when I use the -list argument.
I'm also not sure why the other errors about illegal values crop up.
-- Ketan
Re: Problems with p2-izing a product [message #121627 is a reply to message #121587] |
Wed, 26 November 2008 09:18   |
I think the errors you get are because the "update site url" of some
feature are empty.
Maybe these errors are critical, and it's because the installable unit
com.thoughtworks.twist.eclipse.ui.product can not been found.
I encounter the same problems as you, so confirmations are welcome !
Ketan Padegaonkar wrote:
> doing.
> <java
> </java>
> 00:39:55.022
> 00:39:55.023
> 00:39:55.024
> 00:39:55.026
> 00:39:55.027
> 00:39:55.029
> 00:39:55.030
> 00:39:55.032
> [java]
> 00:41:43.818
> -- Ketan
Re: Problems with p2-izing a product [message #121640 is a reply to message #121587] |
Wed, 26 November 2008 12:44   |
--------------030500030000020105010105
> doing.
> <java
> </java>
> 00:39:55.022
> 00:39:55.023
> 00:39:55.024
> 00:39:55.026
> 00:39:55.027
> 00:39:55.029
> 00:39:55.030
> 00:39:55.032
> [java]
> 00:41:43.818
> -- Ketan
Ketan:
I have been having very similar problems myself. After reading your post
I realized that I did not have the "file:" specified on my repository
arguments. After changing that, I have successfully made it work. Follow
the steps outlined at http://toedter.com/blog/?p=27 up to step 5, except
make the product id be "com.acme.rcp.product".
Then, instead of "running the director app" in step 5, simply run the
attached ant file. You will almost certainly need to change a few of the
properties at the top to be the same as your installation as well as the
p2 params in the p2-install target a few lines below.
Note that I export my files to "C:\test" with a root directory of
"eclipse". Also, the p2Build.xml script seems to take a bleeding
lifetime to run on my machine (about 3 minutes), so if it seems to be
stuck, just give it a bit. I think this is due to me having 1100
plug-ins in my target.
Let me know if you have any trouble! I'm going to work on getting it to
update next!
-TF
Content-Type: text/xml;
name="p2Build.xml"
Content-Disposition: inline;
filename="p2Build.xml"
PHByb2plY3QgbmFtZT0iUDItaXplIHRoZSBleHBvcnRlZCBwcm9kdWN0IiBk ZWZhdWx0PSJi
dWlsZC1hbGwiPg0KDQoJPHByb3BlcnR5IG5hbWU9ImJhc2VMb2NhdGlvbiIg dmFsdWU9IkM6
L3Rlc3QiIC8+DQoJPHByb3BlcnR5IG5hbWU9InJvb3REaXJlY3RvcnkiIHZh bHVlPSJlY2xp
cHNlIiAvPg0KCTxwcm9wZXJ0eSBuYW1lPSJpbnN0YWxsTG9jYXRpb24iIHZh bHVlPSIke2Jh
c2VMb2NhdGlvbn0vJHtyb290RGlyZWN0b3J5fSIgLz4NCgkNCgk8cHJvcGVy dHkgbmFtZT0i
bGF1bmNoZXIudmVyc2lvbiIgdmFsdWU9Il8xLjAuMTAxLlIzNHhfdjIwMDgw ODE5IiAvPg0K
DQoJPHRhcmdldCBuYW1lPSJidWlsZC1hbGwiPg0KDQoJCTxlY2hvIG1lc3Nh Z2U9IkJ1aWxk
IHN0YXJ0aW5nLi4uIiAvPg0KCQk8ZWNobyBtZXNzYWdlPSJJbml0aWFsaXpp bmcgUHJvcGVy
dGllcy4uLiIgLz4NCg0KCQk8YW50Y2FsbCB0YXJnZXQ9InAyLWluc3RhbGwi Pg0KCQkJPHBh
cmFtIG5hbWU9InAyLnJlcG8iIHZhbHVlPSIke2Jhc2VMb2NhdGlvbn0vcmVw b3NpdG9yeSIg
Lz4NCgkJCTxwYXJhbSBuYW1lPSJwMi5JVSIgdmFsdWU9ImNvbS5hY21lLnJj cC5wcm9kdWN0
IiAvPg0KCQkJPHBhcmFtIG5hbWU9InAyLnZlcnNpb24iIHZhbHVlPSIxLjAu MCIgLz4NCgkJ
CTxwYXJhbSBuYW1lPSJwMi5wcm9maWxlIiB2YWx1ZT0iQUNNRVByb2ZpbGUi IC8+DQoJCTwv
YW50Y2FsbD4NCgk8L3RhcmdldD4NCg0KCTx0YXJnZXQgbmFtZT0icDItaW5z dGFsbCI+DQoN
CgkJPGVjaG8gbWVzc2FnZT0iQmFzZSBMb2NhdGlvbjogJHtiYXNlTG9jYXRp b259IiAvPg0K
CQk8ZWNobyBtZXNzYWdlPSJJbnN0YWxsIExvY2F0aW9uOiAke2luc3RhbGxM b2NhdGlvbn0i
IC8+DQoJCTxlY2hvIG1lc3NhZ2U9IlJlcG9zaXRvcnkgTG9jYXRpb246ICR7 cDIucmVwb30i
IC8+DQoNCgkJPGVjaG8gbWVzc2FnZT0iSW5zdGFsbGFibGUgVW5pdDogJHtw Mi5JVX0iIC8+
DQoJCTxlY2hvIG1lc3NhZ2U9IlByb2ZpbGU6ICR7cDIucHJvZmlsZX0iIC8+ DQoNCgkJPGph
dmENCgkJCWphcj0iQzovUHJvZ3JhbSBGaWxlcyAoeDg2KS9lY2xpcHNlIDMu NC9wbHVnaW5z
L29yZy5lY2xpcHNlLmVxdWlub3gubGF1bmNoZXIke2xhdW5jaGVyLnZlcnNp b259LmphciIN
CgkJCWZhaWxvbmVycm9yPSJ0cnVlIiBmb3JrPSJ0cnVlIj4NCg0KCQkJPGFy ZyBsaW5lPSIt
Y2xlYW4gLWNvbnNvbGVMb2cgLWRlYnVnIC1ub3NwbGFzaCAtLWxhdW5jaGVy LnN1cHByZXNz
RXJyb3JzIiAvPg0KCQkJPGFyZyBsaW5lPSItYXBwbGljYXRpb24gb3JnLmVj bGlwc2UuZXF1
aW5veC5wMi5kaXJlY3Rvci5hcHAuYXBwbGljYXRpb24iIC8+DQoNCgkJCTxh cmcgbGluZT0i
LW1ldGFkYXRhUmVwb3NpdG9yeSBmaWxlOiR7cDIucmVwb30iIC8+DQoJCQk8 YXJnIGxpbmU9
Ii1hcnRpZmFjdFJlcG9zaXRvcnkgZmlsZToke3AyLnJlcG99IiAvPg0KDQoJ CQk8YXJnIGxp
bmU9Ii1pbnN0YWxsSVUgJHtwMi5JVX0iIC8+DQoNCgkJCTwhLS0NCgkJCTxh cmcgbGluZT0i
LWxpc3QiIC8+IA0KCQkJIC0tPg0KDQoJCQk8YXJnIGxpbmU9Ii12ZXJzaW9u ICR7cDIudmVy
c2lvbn0iIC8+DQoJCQk8YXJnIGxpbmU9Ii1kZXN0aW5hdGlvbiAke2luc3Rh bGxMb2NhdGlv
bn0iIC8+DQoJCQk8YXJnIGxpbmU9Ii1idW5kbGVwb29sICR7aW5zdGFsbExv Y2F0aW9ufSIg
Lz4NCg0KCQkJPGFyZyBsaW5lPSItcHJvZmlsZSAke3AyLnByb2ZpbGV9IiAv Pg0KCQkJPGFy
ZyBsaW5lPSItcHJvZmlsZVByb3BlcnRpZXMgb3JnLmVjbGlwc2UudXBkYXRl Lmluc3RhbGwu
ZmVhdHVyZXM9dHJ1ZSIgLz4NCg0KCQkJPGFyZyBsaW5lPSItcDIub3Mgd2lu MzIiIC8+DQoJ
CQk8YXJnIGxpbmU9Ii1wMi53cyB3aW4zMiIgLz4NCgkJCTxhcmcgbGluZT0i LXAyLmFyY2gg
eDg2IiAvPg0KDQoJCQk8YXJnIGxpbmU9Ii1yb2FtaW5nIiAvPg0KDQoJCQk8 anZtYXJnIHZh
bHVlPSItRGVjbGlwc2UucDIuZGF0YS5hcmVhPSR7aW5zdGFsbExvY2F0aW9u fS9wMiIgLz4N
CgkJPC9qYXZhPg0KDQoJCTxlY2hvIG1lc3NhZ2U9IkJ1aWxkIGZpbmlzaGVk IiAvPg0KDQoJ
PC90YXJnZXQ+DQoNCjwvcHJvamVjdD4=
--------------030500030000020105010105--
Re: Problems with p2-izing a product [message #121654 is a reply to message #121627] |
Wed, 26 November 2008 13:05   |
You are correct about the update site URL being incorrect, the update
site URL is the URL where we'd be publishing the artifacts *after* it
builds.
I'm still in the dark about what is to be done about this, since I do
not wish to change all my feature.xmls to an intermediate update site
and forget about changing it back when it's time to make a release.
The more I look at it, the whole p2 mechanism just looks like black
magic to me :(
-- Ketan
> feature are empty.
>> doing.
>> <java
>> </java>
>> 00:39:55.022
>> 00:39:55.023
>> 00:39:55.024
>> 00:39:55.026
>> 00:39:55.027
>> 00:39:55.029
>> 00:39:55.030
>> 00:39:55.032
>> [java]
>> 00:41:43.818
>> [java] The installable unit com.thoughtworks.twist.eclipse.ui.product
>> has not been found.
>> -- Ketan
Re: Problems with p2-izing a product [message #121693 is a reply to message #121640] |
Wed, 26 November 2008 14:34   |
Hi TF,
Thanks for the snippet. I've had to make a minor change to what you
suggested here. I've changed the p2.IU to use my feature instead of my
product.
The command still seems to take a very long time while it talks to a lot
of internet servers.
It does manage to create a p2 directory in the install directory, but I
still get the infamous "Cannot launch the Update UI. This installation
has not been properly configured for Software Updates"
-- Ketan
>> doing.
>> <java
>> </java>
>> 00:39:55.022
>> 00:39:55.023
>> 00:39:55.024
>> 00:39:55.026
>> 00:39:55.027
>> 00:39:55.029
>> 00:39:55.030
>> 00:39:55.032
>> [java]
>> 00:41:43.818
>> has not been found.
>> -- Ketan
> Ketan:
> update next!
> -TF
Re: Problems with p2-izing a product [message #121719 is a reply to message #121693] |
Wed, 26 November 2008 15:53  |
Ketan:
I honestly don't know everything that changes when an app is p2-ized,
so I can't tell you which files get changed (I looked for a few minutes
but didn't figure it out).
The output of the p2Build.xml should say:
[java] Installing com.acme.rcp.product 1.0.0.
[java] Operation completed in 68860 ms.
[echo] Build finished
BUILD SUCCESSFUL
Total time: 1 minute 39 seconds
or whatever feature/product you are installing.
Have you been able to get it to work for the standalone test using the
RCP Mail Example? I would give it a try to make sure that it works. If
so, my first guess would be that there might be problems with using a
feature instead of a product. I know that other people have had
difficulty with branding when using a product that used features instead
of one based off of plug-ins.
In any case, I plan on working on a tutorial this weekend (screencast or
something) and I will post it in reply to this thread when I get back on
Monday. I will be out for Thanksgiving until then. Let me know how it
works out for you!
-Topher Fangio
> Hi TF,
> product.
> -- Ketan
>>> Hi,
>>> doing.
>>> <java
>>> </java>
>>> 00:39:55.022
>>> 00:39:55.023
>>> 00:39:55.024
>>> 00:39:55.026
>>> 00:39:55.027
>>> 00:39:55.029
>>> 00:39:55.030
>>> 00:39:55.032
>>> [java]
>>> 00:41:43.818
>>> has not been found.
>>> -- Ketan
>> Ketan:
>> update next!
>> -TF
Current Time: Mon Jun 02 20:21:48 EDT 2025
Powered by FUDForum. Page generated in 0.02928 seconds
