Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Cascade deletes causing not null constraint violations.
| [Teneo] Cascade deletes causing not null constraint violations. [message #121555] |
Wed, 30 April 2008 15:19   |
Eclipse User  |
 I'm having difficulty deleting child objects on a merge call.  I have a
parent object, Lab, which contains a list of Contacts:
<xsd:complexType name="Lab">
    <xsd:annotation>
        <xsd:appinfo source="teneo.jpa">
        @Entity
        @Table(
          name="LabTable"
        </xsd:appinfo>
    </xsd:annotation>
    <xsd:sequence>
<!--lots of irrelevent stuff--->
        <xsd:element maxOccurs="unbounded" minOccurs="0" name="contactList"
type="Contact">
            <xsd:annotation>
                @OneToMany(indexed=false)
                @JoinColumn(name="LAB_SK", nullable=false)
                </xsd:appinfo>
            </xsd:annotation>
        </xsd:element>
    </xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Contact">
    <xsd:annotation>
        @Entity
        @Table(
          name="ContactTable"
        </xsd:appinfo>
    </xsd:annotation>
    <xsd:sequence>
        <xsd:element default="0" name="contactSK" type="xsd:int">
   <xsd:annotation>
     @Id
     @GeneratedValue(strategy=SEQUENCE, generator="labSequence")
     @Column(name=Contact_SK,nullable="false",updatable=false)
   </xsd:appinfo>
          </xsd:annotation>
        </xsd:element>
    </xsd:sequence>
</xsd:complexType>
The Lab is loaded by a client via a web service, so it is completely
serialized and deserialized before it comes back into the system as a
detatched object.  The client has monkeyed with the data he pulled down, and
occasionally removes a contact from the contactList.  To handle the incoming
changes, I'm using the hibernate merge method:
//bunch of deserialization code
outputLab = (Lab)session.merge(inputLab)
//bunch of serialization code
Beautifully simple, and works as advertised.  My problem is that when
hibernate removes a row from the ContactTable, it nulls out the foreign key
first (summarized SQL):
--bunch of selects
update LabTable set lab_sk=null where lab_sk=? and contact_sk=?
delete from ContactTable where contact_sk=?
This causes a foreign key not null constraint violation.  I have "fixed" the
issue by asking the DBA to drop the not null constraints for the moment
(then repremanding myself sternly for even suggesting the idea), but would
like hibernate to please just delete the row without nulling it.
It appears that the standard hibernate way to do this is to add an
'inverse="true"' to the oneToMany:
http://forum.hibernate.org/viewtopic.php?p=2383090
but I can't figure out how to get a Teneo annotation to do that.
Any thoughts or ideas?  Is this the right approach?
-Alex
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #121734 is a reply to message #121555] |
Fri, 02 May 2008 01:53    |
Eclipse User  |
Hi Alex,
I am not sure that I understand the relational schema, but maybe I am missing something.
When removing the contact the following sql is executed:
But why is there a contact_sk column in the LabTable as this is the table containing the Lab
instances? And why is it nulling the lab_sk while this is the pk of the LabTable (afaics).
As the Contact is contained by the Lab, I would expect a fk from ContactTable to LabTable.
gr. Martin
Alex Black wrote:
> Hello,
>     <xsd:annotation>
>         @Entity
>         @Table(
>           name="LabTable"
>         </xsd:appinfo>
>     </xsd:annotation>
>     <xsd:sequence>
> type="Contact">
>             <xsd:annotation>
>                 </xsd:appinfo>
>             </xsd:annotation>
>         </xsd:element>
>     </xsd:sequence>
> </xsd:complexType>
>     <xsd:annotation>
>         @Entity
>         @Table(
>           name="ContactTable"
>         </xsd:appinfo>
>     </xsd:annotation>
>     <xsd:sequence>
>    <xsd:annotation>
>      @Id
>    </xsd:appinfo>
>           </xsd:annotation>
>         </xsd:element>
>     </xsd:sequence>
> </xsd:complexType>
> --bunch of selects
> -Alex
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #121776 is a reply to message #121734] |
Fri, 02 May 2008 11:49    |
Eclipse User  |
Hi Martin,
    I apologize, you are correct, when I translated the SQL from our own
incomprehensible table names I made a mistake, the summarized sql should
look like this:
update ContactTable set lab_sk=null where lab_sk=? and contact_sk=?
The behavior I'd like is simply:
The generated hibernate mapping for the list might help too:
<bag name="contactList" lazy="true" cascade="all,delete-orphan">
    <key update="true" foreign-key="lab_contactlist">
        <column name="lab_sk" not-null="true" unique="false"/>
    </key>
    <one-to-many entity-name="Contact"/>
</bag>
The hibernate discussion forums seem to say that adding 'inverse="true"':
inverse="true">
    </key>
</bag>
will allow this.  I'm curious if you think that is correct and if so, how to
get teneo to do that?
Thanks for all your help!
-Alex
"Martin Taal" <mtaal@elver.org> wrote in message
news:fveap3$716$3@build.eclipse.org...
> Hi Alex,
> missing something.
> containing the Lab instances? And why is it nulling the lab_sk while this
> gr. Martin
> Alex Black wrote:
>> Hello,
>>     <xsd:annotation>
>>         @Entity
>>         @Table(
>>           name="LabTable"
>>         </xsd:appinfo>
>>     </xsd:annotation>
>>     <xsd:sequence>
>> name="contactList" type="Contact">
>>             <xsd:annotation>
>>                 </xsd:appinfo>
>>             </xsd:annotation>
>>         </xsd:element>
>>     </xsd:sequence>
>> </xsd:complexType>
>>     <xsd:annotation>
>>         @Entity
>>         @Table(
>>           name="ContactTable"
>>         </xsd:appinfo>
>>     </xsd:annotation>
>>     <xsd:sequence>
>>    <xsd:annotation>
>>      @Id
>>    </xsd:appinfo>
>>           </xsd:annotation>
>>         </xsd:element>
>>     </xsd:sequence>
>> </xsd:complexType>
>> and occasionally removes a contact from the contactList.  To handle the
>> incoming changes, I'm using the hibernate merge method:
>> key first (summarized SQL):
>> --bunch of selects
>> the issue by asking the DBA to drop the not null constraints for the
>> moment (then repremanding myself sternly for even suggesting the idea),
>> but would like hibernate to please just delete the row without nulling
>> it.
>> Thanks,
>> -Alex
> The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #121868 is a reply to message #121776] |
Mon, 05 May 2008 13:18    |
Eclipse User  |
Hi Alex,
I understand what you mean. However, teneo on purpose does not set inverse=true because
bidirectional relations are handled by emf and if hibernate also handles bi-directional relations
then it does not work well. I re-tested this yesterday and many of my testcases fail if I add
inverse=true. So I will need to look in more detail at this.
Can you enter a bugzilla for this? Then I can take some more time to look at it.
I am on holiday, so I can't spend to much time on this, this week.
gr. Martin
Alex Black wrote:
> Hi Martin,
> look like this:
>     </key>
> </bag>
> inverse="true">
>     </key>
> </bag>
> -Alex
>> Hi Alex,
>> missing something.
>> gr. Martin
>> Alex Black wrote:
>>> Hello,
>>>     <xsd:annotation>
>>>         @Entity
>>>         @Table(
>>>           name="LabTable"
>>>         </xsd:appinfo>
>>>     </xsd:annotation>
>>>     <xsd:sequence>
>>>             <xsd:annotation>
>>>                 </xsd:appinfo>
>>>             </xsd:annotation>
>>>         </xsd:element>
>>>     </xsd:sequence>
>>> </xsd:complexType>
>>>     <xsd:annotation>
>>>         @Entity
>>>         @Table(
>>>           name="ContactTable"
>>>         </xsd:appinfo>
>>>     </xsd:annotation>
>>>     <xsd:sequence>
>>>    <xsd:annotation>
>>>      @Id
>>>    </xsd:appinfo>
>>>           </xsd:annotation>
>>>         </xsd:element>
>>>     </xsd:sequence>
>>> </xsd:complexType>
>>> --bunch of selects
>>> it.
>>> Thanks,
>>> -Alex
>> The Netherlands
The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #127755 is a reply to message #121868] |
Wed, 30 July 2008 14:04    |
Eclipse User  |
Hi Martin,
    I apologize for being three months late with this, but this has recently
become an  issue for us again.  I've created a bug and submitted it:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242479
Thanks!
-Alex
news:fvnfgs$cfi$1@build.eclipse.org...
> Hi Alex,
> inverse=true because bidirectional relations are handled by emf and if
> hibernate also handles bi-directional relations then it does not work
> at it.
> gr. Martin
> Alex Black wrote:
>> Hi Martin,
>> look like this:
>>     </key>
>> </bag>
>> inverse="true">
>>     </key>
>> </bag>
>> to get teneo to do that?
>> -Alex
>>> Hi Alex,
>>> missing something.
>>> table containing the Lab instances? And why is it nulling the lab_sk
>>> gr. Martin
>>> Alex Black wrote:
>>>> Hello,
>>>> a parent object, Lab, which contains a list of Contacts:
>>>>     <xsd:annotation>
>>>>         @Entity
>>>>         @Table(
>>>>           name="LabTable"
>>>>         </xsd:appinfo>
>>>>     </xsd:annotation>
>>>>     <xsd:sequence>
>>>>             <xsd:annotation>
>>>>                 </xsd:appinfo>
>>>>             </xsd:annotation>
>>>>         </xsd:element>
>>>>     </xsd:sequence>
>>>> </xsd:complexType>
>>>>     <xsd:annotation>
>>>>         @Entity
>>>>         @Table(
>>>>           name="ContactTable"
>>>>         </xsd:appinfo>
>>>>     </xsd:annotation>
>>>>     <xsd:sequence>
>>>>    <xsd:annotation>
>>>>      @Id
>>>>    </xsd:appinfo>
>>>>           </xsd:annotation>
>>>>         </xsd:element>
>>>>     </xsd:sequence>
>>>> </xsd:complexType>
>>>> down, and occasionally removes a contact from the contactList.  To
>>>> handle the incoming changes, I'm using the hibernate merge method:
>>>> --bunch of selects
>>>> "fixed" the issue by asking the DBA to drop the not null constraints
>>>> for the moment (then repremanding myself sternly for even suggesting
>>>> the idea), but would like hibernate to please just delete the row
>>>> without nulling it.
>>>> Thanks,
>>>> -Alex
>>> The Netherlands
> The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #127768 is a reply to message #127755] |
Wed, 30 July 2008 14:08   |
Eclipse User  |
Hi Alex,
No problem, I have seen the bugzilla. I will probably add an annotation attribute on the one-to-many
or many-to-one to signal that inverse=true should be put in the mapping. I hope to solve this and
some other issues around this weekend.
Btw, support for Teneo is now given on the EMF newsgroup which I cc-ed.
gr. Martin
Alex Black wrote:
> Hi Martin,
> Thanks!
> -Alex
>> Hi Alex,
>> at it.
>> gr. Martin
>> Alex Black wrote:
>>> Hi Martin,
>>> look like this:
>>>     </key>
>>> </bag>
>>> inverse="true">
>>>     </key>
>>> </bag>
>>> -Alex
>>>> Hi Alex,
>>>> missing something.
>>>> gr. Martin
>>>> Alex Black wrote:
>>>>> Hello,
>>>>>     <xsd:annotation>
>>>>>         @Entity
>>>>>         @Table(
>>>>>           name="LabTable"
>>>>>         </xsd:appinfo>
>>>>>     </xsd:annotation>
>>>>>     <xsd:sequence>
>>>>>             <xsd:annotation>
>>>>>                 </xsd:appinfo>
>>>>>             </xsd:annotation>
>>>>>         </xsd:element>
>>>>>     </xsd:sequence>
>>>>> </xsd:complexType>
>>>>>     <xsd:annotation>
>>>>>         @Entity
>>>>>         @Table(
>>>>>           name="ContactTable"
>>>>>         </xsd:appinfo>
>>>>>     </xsd:annotation>
>>>>>     <xsd:sequence>
>>>>>    <xsd:annotation>
>>>>>      @Id
>>>>>    </xsd:appinfo>
>>>>>           </xsd:annotation>
>>>>>         </xsd:element>
>>>>>     </xsd:sequence>
>>>>> </xsd:complexType>
>>>>> --bunch of selects
>>>>> without nulling it.
>>>>> Thanks,
>>>>> -Alex
>>>> The Netherlands
>> The Netherlands
The Netherlands
Cell: +31 (0)6 288 48 943
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #617983 is a reply to message #121555] |
Eclipse User  |
Hi Alex,
gr. Martin
Alex Black wrote:
> Hello,
>     <xsd:annotation>
>         @Entity
>         @Table(
>           name="LabTable"
>         </xsd:appinfo>
>     </xsd:annotation>
>     <xsd:sequence>
> type="Contact">
>             <xsd:annotation>
>                 </xsd:appinfo>
>             </xsd:annotation>
>         </xsd:element>
>     </xsd:sequence>
> </xsd:complexType>
>     <xsd:annotation>
>         @Entity
>         @Table(
>           name="ContactTable"
>         </xsd:appinfo>
>     </xsd:annotation>
>     <xsd:sequence>
>    <xsd:annotation>
>      @Id
>    </xsd:appinfo>
>           </xsd:annotation>
>         </xsd:element>
>     </xsd:sequence>
> </xsd:complexType>
> --bunch of selects
> -Alex
The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #617986 is a reply to message #121734] |
Eclipse User  |
Hi Martin,
look like this:
    </key>
</bag>
inverse="true">
    </key>
</bag>
-Alex
> Hi Alex,
> missing something.
> gr. Martin
> Alex Black wrote:
>> Hello,
>>     <xsd:annotation>
>>         @Entity
>>         @Table(
>>           name="LabTable"
>>         </xsd:appinfo>
>>     </xsd:annotation>
>>     <xsd:sequence>
>>             <xsd:annotation>
>>                 </xsd:appinfo>
>>             </xsd:annotation>
>>         </xsd:element>
>>     </xsd:sequence>
>> </xsd:complexType>
>>     <xsd:annotation>
>>         @Entity
>>         @Table(
>>           name="ContactTable"
>>         </xsd:appinfo>
>>     </xsd:annotation>
>>     <xsd:sequence>
>>    <xsd:annotation>
>>      @Id
>>    </xsd:appinfo>
>>           </xsd:annotation>
>>         </xsd:element>
>>     </xsd:sequence>
>> </xsd:complexType>
>> --bunch of selects
>> it.
>> Thanks,
>> -Alex
> The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #617993 is a reply to message #121776] |
Eclipse User  |
Hi Alex,
gr. Martin
Alex Black wrote:
> Hi Martin,
> look like this:
>     </key>
> </bag>
> inverse="true">
>     </key>
> </bag>
> -Alex
>> Hi Alex,
>> missing something.
>> gr. Martin
>> Alex Black wrote:
>>> Hello,
>>>     <xsd:annotation>
>>>         @Entity
>>>         @Table(
>>>           name="LabTable"
>>>         </xsd:appinfo>
>>>     </xsd:annotation>
>>>     <xsd:sequence>
>>>             <xsd:annotation>
>>>                 </xsd:appinfo>
>>>             </xsd:annotation>
>>>         </xsd:element>
>>>     </xsd:sequence>
>>> </xsd:complexType>
>>>     <xsd:annotation>
>>>         @Entity
>>>         @Table(
>>>           name="ContactTable"
>>>         </xsd:appinfo>
>>>     </xsd:annotation>
>>>     <xsd:sequence>
>>>    <xsd:annotation>
>>>      @Id
>>>    </xsd:appinfo>
>>>           </xsd:annotation>
>>>         </xsd:element>
>>>     </xsd:sequence>
>>> </xsd:complexType>
>>> --bunch of selects
>>> it.
>>> Thanks,
>>> -Alex
>> The Netherlands
The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #620164 is a reply to message #121868] |
Eclipse User  |
Hi Martin,
Thanks!
-Alex
> Hi Alex,
> at it.
> gr. Martin
> Alex Black wrote:
>> Hi Martin,
>> look like this:
>>     </key>
>> </bag>
>> inverse="true">
>>     </key>
>> </bag>
>> -Alex
>>> Hi Alex,
>>> missing something.
>>> gr. Martin
>>> Alex Black wrote:
>>>> Hello,
>>>>     <xsd:annotation>
>>>>         @Entity
>>>>         @Table(
>>>>           name="LabTable"
>>>>         </xsd:appinfo>
>>>>     </xsd:annotation>
>>>>     <xsd:sequence>
>>>>             <xsd:annotation>
>>>>                 </xsd:appinfo>
>>>>             </xsd:annotation>
>>>>         </xsd:element>
>>>>     </xsd:sequence>
>>>> </xsd:complexType>
>>>>     <xsd:annotation>
>>>>         @Entity
>>>>         @Table(
>>>>           name="ContactTable"
>>>>         </xsd:appinfo>
>>>>     </xsd:annotation>
>>>>     <xsd:sequence>
>>>>    <xsd:annotation>
>>>>      @Id
>>>>    </xsd:appinfo>
>>>>           </xsd:annotation>
>>>>         </xsd:element>
>>>>     </xsd:sequence>
>>>> </xsd:complexType>
>>>> --bunch of selects
>>>> without nulling it.
>>>> Thanks,
>>>> -Alex
>>> The Netherlands
> The Netherlands
| Re: [Teneo] Cascade deletes causing not null constraint violations. [message #620165 is a reply to message #127755] |
Eclipse User  |
Hi Alex,
gr. Martin
Alex Black wrote:
> Hi Martin,
> Thanks!
> -Alex
>> Hi Alex,
>> at it.
>> gr. Martin
>> Alex Black wrote:
>>> Hi Martin,
>>> look like this:
>>>     </key>
>>> </bag>
>>> inverse="true">
>>>     </key>
>>> </bag>
>>> -Alex
>>>> Hi Alex,
>>>> missing something.
>>>> gr. Martin
>>>> Alex Black wrote:
>>>>> Hello,
>>>>>     <xsd:annotation>
>>>>>         @Entity
>>>>>         @Table(
>>>>>           name="LabTable"
>>>>>         </xsd:appinfo>
>>>>>     </xsd:annotation>
>>>>>     <xsd:sequence>
>>>>>             <xsd:annotation>
>>>>>                 </xsd:appinfo>
>>>>>             </xsd:annotation>
>>>>>         </xsd:element>
>>>>>     </xsd:sequence>
>>>>> </xsd:complexType>
>>>>>     <xsd:annotation>
>>>>>         @Entity
>>>>>         @Table(
>>>>>           name="ContactTable"
>>>>>         </xsd:appinfo>
>>>>>     </xsd:annotation>
>>>>>     <xsd:sequence>
>>>>>    <xsd:annotation>
>>>>>      @Id
>>>>>    </xsd:appinfo>
>>>>>           </xsd:annotation>
>>>>>         </xsd:element>
>>>>>     </xsd:sequence>
>>>>> </xsd:complexType>
>>>>> --bunch of selects
>>>>> without nulling it.
>>>>> Thanks,
>>>>> -Alex
>>>> The Netherlands
>> The Netherlands
The Netherlands
 Current Time: Mon Nov 03 19:18:43 EST 2025
 Powered by  FUDForum. Page generated in 0.05887 seconds
